Question about Sharper Image Professional Plus Ionic Breeze GP (SI871) Air Purifier
Red Cleaning Light is On
I've cleaned the blades as usual, however, a red has come on that says "cleaning overdue" and won't turn off. The unit is not working...
Please help!
  • 9 more comments
  • kmsmoore Jan 01, 2008
    I have the same problem. We clean the filter yet the red light indicating the need to clean it comes on almost immediately after turning it back on. The unit doesn't seem to be working.
  • Anonymous Jan 18, 2008
    I cleaned the unit. I plugged it in and the red light won't go off and let the unit operate. I tried the turning upside down, didn't work.........now what?
  • TBolan Feb 11, 2008
    Our dog knocked it over, and the light won't go off no matter how thorough we clean it.
  • capine Feb 21, 2008
    Cleaned it thuroughly, turned it upside down, etc., but it still sputters and snaps when it is first turned on and occasionally thereafter, and then after about 10-15 minutes, the red "cleaning overdue" flashes on, and the unit shuts down.  Also, the "Blue/Green  Boost Ions" button no longer works.
  • jwdrive Jun 18, 2008
    red light is on , have cleaned unit,it still does not claen
  • Sandy Glover Sep 03, 2008
    Cleaned blades, vaccuumed, red light stays on blinking at times, sputters
  • Anonymous Sep 11, 2008
    i have 2 of them one went out 1st the red light came on an i cleaned it several times an nothing then 1month later the other if i leave it on it doesnt clean the air
  • mmgallagher1 Sep 16, 2008
    I cleaned the unit when the cleaning light came on and now the light is continually blinking red. The unit starts up but sputters and then quits.
  • Anonymous Sep 22, 2008
    I have cleaned the blades and the red light comes on as soon as I put the blades back in and it won't turn on and it smells funny.
  • rybar926 Oct 13, 2008
    I have the same problem. I have had the purifier for over 5 years and never had a problem. All of a sudden the red clean light is on and doesn't work. I took it apart and cleaned it. Still not working. Should I get a new bulb? Does that have anything to do with it? Thanks.
  • bennettpd
    bennettpd Jul 18, 2012
    i purchased 2 of these units. BOTH were new and BOTH have done the same thing. Perhaps is the reason that Sharper Image went under.
I have the same problem. I totally took the unit apart and cleaned it out. After I reasembled it, the same thing. Just that little cleaning overdue light on. I can tell that it is not working as well as there is no breeze coming from the front. That is what I get for buying a serviced unit.
Posted on Feb 16, 2008
Ionic Breeze Midi Prof. Plus has red light on and won't work
When you cleaned everything did you also turn the whole unit upside down and gently shake to remove trapped dirt in the bottom of the unit. As for taking this unit apart to clean throughly there is no need. Just use some q-tips with 91% Isopropal alcohol not Rubbing alcohol to get to the small areas. Pay close attention to the small arrow shaped metal contact near the bottom of the unit. Make sure it is wiped clean and everything is completely dry. Plug unit back into power and the red button should turn green.
Mar 22, 2010 | Sharper Image Professional Plus Ionic...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
I have a sharper image midi and the red light (cleaning overdue)stays on even after cleaning? Will it still work with the light on? My real question how to fix it
Same problem : after cleaning thoroughly inside by removing the Front& Rear Plastic grid and the stainless blades, I also cleaned the 2wires (very softly and carrefully, not to break them), but the Redlight goes on after only few minutes :
Here is my Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no more Red light. Maybe it will work for you. I also found this other bit of information. Since then I have discovered a lot of information on the midi. Here is some more reading material that might interest you.
Could be a blade replacement needed but Sharper Image2.gifrecalled the product. Since it was proven in court that it wasn'teffectively cleaning the air by Consumer Reports as well as EPA data. As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commissionis going to be making a decision on ionizers at the end of year sincethere are hazards in the air from using the devices. It could be thationizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it. The next step to do if you can't get it to work is to file a report with the company.
The Ionic Breeze would work for a short time after cleaning and the bluelight would start flashing again. We checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So we went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so we don't use it anymore.
Best wishes. Hope this helps you. If not please leave me a comment and I will do some more research.
Aug 22, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Feb 22, 2009 | Sharper Image Ionic Breeze 3.0 Air...
"clean" light
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
Jul 31, 2008 | Sharper Image Professional Plus Ionic...
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
RED CLEAN LIGHT
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Mar 27, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Sharper Image Professional Plus  Ionic Breeze GP  (SI871) Air Purifier Logo
945 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
