Question about Kenmore 24902 Top Load Washer
How do I clean the fabric softener dispenser. It seems to be clogged
  • 612 Answers
You can remove it and wash it out in the sink. I use a toothbrush, hot water and Mean Green.
Please rate solution
Posted on Sep 05, 2009
How to replace blue fabric softener dispenser? Came out easily but cannot replace it. Thank You LG WT1101CW
SOURCE:Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Mar 23, 2018 | LG Washing Machines
Front loader. Why doesn't fabric softener dispenser empty?
It can be two things. First, what is left in the dispenser? If its the fabric softener, then the water valve may be faulty. The water valve will have multiple feeds and the fabric softener might be bad. If its a combination of water and softener, then the dispenser might be clogged. You can remove the slide out tray and clean it. Look for build up of fabric softener that might be there. Good Luck?
Nov 23, 2015 | Frigidaire Washing Machines
Kenmore frontloader fabric softener dispenser is clogged
There should be pins located somewhere on the dispenser or a grey thing located inside the dispenser, push it down and that will release the dispenser from the washer. Afterwards you can put in in the dishwasher, this should clean out any clogging residue.
Mar 10, 2013 | Washing Machines
Fabric softener dispenser will not empty
Hello Mike Oswald - Fabric Softener is a very thick liquid that can clog up the siphoning mechanism. Try the following steps below.
  1. Remove the Dispenser
  2. Remove the Inset in the dispenser
  3. Clean out the dispenser and dispenser cover
The Fabric dispenser needs to have the hot and cold water at equal pressure for the fabric softener dispenser to operate properly.
1. Turn on the hot water fill then cold water fill at the washer. If the Wash Sense or temperature sensing is on it needs to be off.
  • If they seem to fill at the same pressure then you will need to contact a professioanl to move forward accurately.
  • If they seem not to fill at the same then you need to correct the pressure.
Mar 03, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
The part where I pour fabric softener in it seems to be clogged somehow. I cleaned it out and it seems to still be clogged is there any suggestions that you can give me?? Please help...thanks!!
Are you sure you have water flow to the reservoir?
Does it look like the Fabric Softener is diluted with water flow?
The Service Manual for reference. Sears Parts Direct for reference.
See page 33 of the Service Manual for Bleach/Softener Dispenser Removal but I don’t think that is your problem….Rich
See page 16 of the Service Manual to go into Board Output Test. Turn on the Fabric Softener Valve and see if you hear the solenoid hum then turn on the Cold water valve and see if the dispenser fills and flushes with cold water. If not then you need to begin troubleshooting at the dispenser valve. This valve can be seen on page 36 lower left side pic and top right side pic…..Rich
Jun 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clogged fabric Softener
I had the same issue, and ran vinegar through the fabric dispenser with a load of towels. Not only did it solve the 'sour towel' problem I had with that load, it also cleared my fabric softener section. Now, I water down all fabric softner when I use it, which is less frequently!
~Steph
Nov 11, 2008 | GE Energy Star WCVH6260F Front Load Washer
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 24902 Top Load Washer Logo
168 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
