Question about Casio Cameras
Can pictures be taken on Casio EX-Z9 without SD card & then transferred to computer using USB cable?
SOURCE:
jackboy
  • 2985 Answers
SOURCE: lost my usb cable
Your camera manual will tell if transfer from internal memory to card is possible.Some do some do not. Another USB cord should not be very expensive
Posted on Aug 29, 2007
pshinde23
  • 136 Answers
SOURCE: My computer does not recognize my SD 2GB SD Flash
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Posted on Jun 25, 2009
Obertelli
  • 3006 Answers
SOURCE: I need a camera cable (USB) for my casio EX-Z9
You can get the correct lead from almost any large computer or photographic store, it does not have to be the official Casio item.
The lead needs to be a standard USB socket at one end (USB type A) and the other end is a micro USB (micro USB type B). This is by far the most common type for many cameras and phones now so shouldn't be expensive or difficult to find.
Alternatively, ditch the cable altogether and use an external card reader. Removing your memory card and putting it into an external reader to transfer images is usually much faster, especially if you also avoid using the clunky and non-essential software which most cameras are supplied with.
I hope that you've found my reply to be of use and ask in return only that you rate my answer.
Posted on Nov 05, 2009
Testimonial: "Great help. Thanks."
SOURCE: CASIO EX-Z75 CAMERA CABLE
I called Parts Replacement at 1-800-223-2001 and they told me I would have to purchase the USB Cable for my casio exilim ex-z75 over the phone for $4 (part) + $4.95 (S&H) because it not sold ANYWHERE online. I was hoping to get a cheap cable for a few bucks, but this is better than nothing!
Posted on Jan 14, 2010
  • 11967 Answers
SOURCE: coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Posted on Feb 07, 2010
I put pictures on my sd card useing my camera but when i try to upload them to my computer it says that there are no new pictures to upload
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 26, 2013 | Casio Exilim EX-Z30 Digital Camera
Driver for casio exilim sd card
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 01, 2013 | Casio Exilim Zoom EX-Z9 Digital Camera
I can see the pictures form my 1 gb sd card in my Casio Exilim. However, I cant see or transfer the pictures when I connect the camera to my laptop via the usb cable? the camera comes up as removalble...
It's good the laptop recognizes the camera as an external drive. A couple of things make sure you are looking at the SD card and not the cameras internal memory. Most point and shooters can't download directly from the internal memory to the computer they need to be transferred to the SD card first. Also if they are on the SD card for sure look to see if you have locked any of them cause that will prevent a download as well. It almost appears as if the SD card became locked which all it will alow you to do is look at teh picture and nothing else. I'm including a diagram of the little lock on the side of the SD card make sure that's in the open position.
Diagram
The position in thee little circle is where it need to be for unlock
Jan 06, 2011 | Casio Exilim EX-Z750 Digital Camera
I need a camera cable (USB) for my casio EX-Z9 exilim. How can I find the right one?
Nov 05, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Sdhc card says error in my printer
SDHC cards work for most cameras but many printers cannot run SDHC cards I have had the same problem and getting a usb cord for my camera worked just fine
Jun 02, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Casio Exilim ex-s600
Why don't you just transfer them onto your memory card? If your computer has an SD slot that would work. In your play mode you would just press menu and then copy to card. Otherwise you are going to have to wait until you get back to your dock with your camera.
Jul 20, 2008 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
