Question about Samsung AW0603B Air Conditioner
My LG window ac continues to shut down after 20 or 25 minutes
The ac will run for about 20 to 25 minutes and then shut off completely. The plug has a breaker and it trips. I can usually push the breaker on the plug and the unit will finally come on.
    Problem Solver:
  • 5 Answers
The button on the plug is a GFI. Ground fault interuppter. Like on your hair dryer. When the unit is running, or has just tripped out, feel the plug and the well receptical. If either feel warm or hot, do not continue to run the A/c unit. Get an electrician to check for a faulty/ worn/improperly wired outlet. The units tripping out for a reason.
Posted on Aug 01, 2009
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
After my air conditioner is on for awhile it will automatically shut off completely then after a few minutes it comes back on. It is not set on the energy saver setting. Also it is and continues to do...
Debi, it;s not unusual for an AC unit to turn ON & OFF. Once it reaches the temperature that you have it set ON and holds the temperature for 4 or 5 minutes, it will shut OFF until the room temperature rises above it. Be sure all the doors and windows are closed and no hot air is infiltrating the area.
Also, a 10,000 BTU air conditioner is not designed to handle a large area. Generally, 10,000 BTU's will handle about 3200 Cubic Feet (20' x 20' x 8' = 3200 sq ft) or simply put, 400 square feet. Your A/C unit may be undersized for the area you're trying to cool.
Hope this helped you. Please let me know. Thanks.
Jun 07, 2011 | LG Electronic Window Air Conditioner
Laptop shuts down after 20 or 30 minutes with one
Please refer to manual and run system restore to system default settings as if it was from the package.
Cheers.
Jan 24, 2010 | Dell InspironĀ® 1501 (N11157) PC Notebook
Computer hard drive is allways active even in the middle of the night...?
Yes, Windows OS's are continually updating swap file which exists on the same drive has the OS. If you computer not actively being used during the night, you should set your power management options to reflect. Most have option to shut down monitor, hard drive and entire system after so many minutes. You can define these parameters for when plugged into AC power or running on battery. I suspect you have these set to always on when connected to AC power.
Oct 12, 2009 | HP Pavilion dv6000z Notebook
LG 1200 btu ac unit works fine for 20 minutes then shuts off compressor and continues to run fan only. Shutting it off for 15 minutes and then works fine again for 20 minutes.
You do not say if it is outdoor or indoor fan which operates. However I presume all your filters are clean and the drainpipes are clear. The only other thing you could suspect is the thermostat or air flow sensor.
Jun 25, 2009 | LG Heating & Cooling
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Power/battery problem
hi, try removing the batt press and hold the power down for 1 minute, dont replace battery yet, plug in charger, boot up then shut down. replace battery and boot.
if this fails you could also try changing your power settings in control panel. change to minimal power managment.
remove the adapter while laptop is on and allow to completly drain(untill it switches off)
then try reboot.
Dec 19, 2008 | HP 530 Notebook PC
Gateway laptop
Probly its overheating and shuting down.But if it do turn on try to run in safe mode by pressing f8 when booting up.
May 28, 2008 | Computers & Internet
Samsung AW0603B Air Conditioner Logo
305 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
