Question about Sony Ericsson Cyber-shot C905 Cell Phone
Bluetooth menu not desplaying - Sony Ericsson Cyber-shot C905 Cell Phone
    Brigadier General:
  • 7,752 Answers
You need to have the phone's firmware reflash on the phone to correct this issue..
Posted on Aug 01, 2009
Blank white scre
You might have done a mistake while flashing and may be your phone has been bricked.consult a local mobile software up-loader in market.
Nov 06, 2013 | Nokia X2-01 RED,BLUETOOTH,FM,QWERTY...
Tip
How to turn Bluetooth on and off on a Samsung Intensity
Like many other cell phones, the Samsung Intensity (SCH U450) is Bluetooth-capable. Turning Bluetooth on and off on the Intensity is easy to do, as is configuring the phone's various Bluetooth options and setting up new connections.
To turn Bluetooth on, press the Menu button (the round button in the upper center of the numeric keypad). On the main menu screen, select the Settings & Tools submenu in the lower right hand corner. Then scroll down to item #3 (Bluetooth Menu) and select it.
If Bluetooth is currently disabled, the option in the lower left corner of the screen will say "Turn On." Press the left option button to turn Bluetooth on; you'll see a box pop up that says "Bluetooth power on." Now you can pair your phone with other Bluetooth devices, either by initiating a connection (choose Add New Device from the Bluetooth menu, or if you've paired with the device before, select it from the list of devices) or by making your phone discoverable (click the right option button, select Discovery Mode, and turn it on).
To disable Bluetooth, go back into the Bluetooth menu and just hit the left option button ("Turn Off"). A box will appear that says "Bluetooth power off."
If you're not sure if Bluetooth is on or off at any given time, just look at the status bar at the top of your Intensity's main screen. If you see the Bluetooth icon -- a sharply-angled white "B" on the blue background -- then Bluetooth is currently enabled.
on Oct 16, 2010 | Samsung SCH-U450 Cell Phone
How do i turn on bluetooth feature on my rumor 2
    • 1 Turn on the Bluetooth-enabled device and enable it to be in "Discovery" mode. Check the owner's manual of the device to learn how to put it in "Discovery" mode.
    • 2 Press "Menu/Ok" on the LG Rumor2, which is the middle button on the phone.
    • 3 Press " * " to access the settings menu.
    • 4 Press "1" for the Connections menu.
    • 5 Press "2" for the Bluetooth menu then press "1." Press "Yes" when prompted to turn on the Bluetooth feature. A list of available devices appears in the menu.
    • 6 Highlight the listed device, which should be showing.
    • 7 Click "Ok."
    • 8 Enter the passkey provided in the owner's manual of the Bluetooth device. The standard passkey is "0000." The Rumor2 is now paired with the Bluetooth device.
    • 9 Press the "Call" key on the phone or the "Call" button on the Bluetooth device to answer calls through a Bluetooth headset while paired.
Mar 01, 2012 | LG Rumor 2 Cell Phone
How do you program the one touch buttons on a DP80F Fax Machine
please go to MENU 32 and follow instructions on desplay of the machine.
Oct 26, 2010 | Toshiba DP80F Printer
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Desplay not working, can I change the desplay and cost
    Yeah you can replace it. I would suggest you to go to a mobile repairing shop and get repaired or you can to the service center. They'll charge you for the new display and for their service.
    Good luck.
    Thanks for using FixYa.
    Jun 17, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
    How to pair with iphone
    Hello
    1.From the main home screen of the iphone open "SETTINGS".
    2.From the setting menu go to "GENERAL".
    3.From General go to "BLUETOOTH".
    4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
    5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
    6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
    7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
    8.After you have entered the correct PIN number press connect.
    9.From here your Bluetooth Headset should be connected and ready to use.
    NOTE:Fully charge your bluetooth headset before syncing it to your iphone
    Goodluck
    Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
    Stopped playing DVDs
    you need to change your desplay settings on the ps3 or chek your hdmi connetion
    Dec 12, 2009 | Sony Playstation 3 (PS3) Console
    N70 DESPLAY HUNG
    You need to reinstall the software of the phone as its corrupted ,get it done if the phone is still under warranty or else get it done in a local mobile repair center ,do it on your own is risky in the process you may damage the phone permanently ............................
    Good luck...
    Sep 02, 2008 | Cell Phones
    Nokia 6280 bluetooth
    sir,u try by going to menu>>settings>.connectivity>bluetooth>bluetooth settings>>bt visibility>>shown to all then restart ur phone after restoring handset then try to turn it on..else there is a fault in handset regarding bluetooth function.
    Oct 14, 2007 | Nokia 6280 Cellular Phone
    Sony Ericsson Cyber-shot C905 Cell Phone Logo
    41 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Sandeep Shenoy
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
