Question about Samsung Refrigerators
RS27fgrs samsung refrigerator makes ice in the tray / not in
RS27fgrs samsung refigerator makes ice in the tray but it does not go into the ice bin
  • Anonymous Mar 13, 2014
    ice off light is blinkuing on samsung refigerator will not make ice
  • Anonymous Mar 18, 2014
    my samsung refrigerator not making enough ice
    Problem Solver:
  • 3 Answers
Well I tried several things.Pressed the power cool button and the Freezer Power button for 12 seconds alternately and bring the option to
3.Befor doing this I had removed the ice bin.There is also a lever behind the ice bin that seem to be out of place.In the manual this lever is seen
touching the ice tray.I tried to bring back the lever to touch the ice tray then replace the ice bin.
After 18 hours-this morning i noticed when i pressed the lever i started
to get ice again.
Not sure if this is a solution but it worked for me.
Posted on Aug 02, 2009
Samsung refrigerator ice maker ice not coming out during harvest water runs into ice bin
if it one of the flex tray models, you need to replace flex tray.
May 20, 2017 | Samsung Refrigerators
How do I get the refrigerator to dump ice
We first need to know if your referring to the ice tray dumping into the bin. Or the ice dumping out into your cup at the front of the refrigerator. If at the bin I maybe the the defrost element on the bottom of the tray that heats up while the fingers spins around to push the ice out from the tray into the bin has burnt out and needs replaced . Most modles require you to replace the entire tray. However if your referring to the front of the refrigerator at the dispenser for you glass. It could be (1) That the trigger switch is bad or touch pad is bad. But if it makes noise as if its trying to bring the ice but it's not then that's not your problem.(2) it could be that the Alger Screw that moves the ice from the chest to the front could have sheared a pin striped the spines or broke at the knuckle.you would only hear the motor running with no ice movement if this was the case(3) and most likely the spout/opening that allows the ice to get from the bin to the Auger has restriction/ frozen block do to improper drainage during defrost cycle. Simply remove the bin inspect and use warm water to clean out obstruction. Hope this help.
Sep 28, 2014 | Samsung RS265TDWP
Hi have a rs21dcns samsung can any one tell me how long it take to produce ice cubes fo the first time as the manual is not clear about this, and is there any tips i should know thanks
The first time should be on the average of 20-25 minutes. If your samsung is taking longer than 30 minutes, it indicates there is a problem. Fiscally look in the ice tray and verify the water is in there. If not, check and make sure the water line to the unit is connected and the water is supplied to the line. If the water is in the ice tray, then make sure your fill lever is in the down position. This lever is designed to stop making ice when the ice bin is full. If the lever is up, it will stop making ice.
Jun 26, 2011 | Samsung RS2630SH Side by Side Refrigerator
No ice is being produced. Should silver bar be up or down?
The bar should be down in ice making mode, if you ever noticed the bar rises upon ejection of ice cubes from the tray, and falls to its postion hovering above the ice bin, as the bin gets full the bar cant lower to the postion indicating a full bin and it willl stop ice making.
Dec 27, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
The icemaker of our Samsung side by side refigerator gets full and clogged up frequently and although we can hear the machine churning inside, ice is not dispensed. We have put in a new water filter after...
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, part number DA63-02284B
Good luck,
Vlad
First Choice Appliance
Aug 17, 2010 | Samsung RS2630SH Side by Side Refrigerator
All the ice in the frizer are stick together.
Hi
Please check the link bellow for your query….
http://kitchenaid.custhelp.com/app/answers/detail/a_id/1762
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jun 30, 2010 | Samsung RF265AA Bottom Freezer French Door...
How can I stop my icemaker from making a block of ice? At the front of the ice bin, a block of ice is forming as though wateer is drippping into the bin.
Open the freezer and remove the ice bucket. You should now see the tray were the ice cubes freeze, check to see if it is fractured or leaking and the position of the water outlet pipe to the ice tray. If the water pipe is firing water out of the tray just readjust it.
hope this helps you.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung rs2630hs
Well, it sounds like your condenser fan motor has seized up and needs to be replaced. I had the same problem and additionally it woudl onhly produce about twenty cubes of ice a day. Best Buy repair guy came replaced the fan motor and within 10 minutes the heat was dissapated from the strip and it started churning out ice agin.
Apr 06, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
310 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
