Question about Altec Lansing ATP 3W Computer Speakers
My conrol cord has its pins distorted
The pins in my control cord were cut.So I just cut the wires and I would like it to be soldered directly into the circuit board. my question is, where should I put the specific wires into its specific location on the board? do you guys know where I could find the circuit diagram? thanks
  • 1 more comment
  • Vincent Alexei Betos Nov 26, 2007
    Its the cable you connect at the back of the Altec Lansing atp3
  • Ian_1969 Apr 13, 2008
    Anyone else have a cirucit of ATP3 board housed inside the subwoofer enclosure or know which pinouts may join up to eliminate the remote switch on the right speaker?
  • chandang Aug 15, 2008
    remote control pod connector broken, needs the wire and pin diagram
  • 3 Answers
Anyone else have a circuit or know which pins could be joined to eliminate the remote switch on the right speaker?
Posted on Apr 13, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Well Friend,
What is the brand , name, model of your mobo, and what "control" is what you talk about.
Posted on Nov 25, 2007
Electric cord chipped power shorting, how do we fix it
You will need a wire stripper, solder, solder flux, heat shrink tubing, a heat gun (hair dryer will do) and a soldering iron.
1. Cut the cord where the chip is.
2. Strip the wire on both sides by about 1/8". You should have 4 exposed wires from the two wires inside the cord.
3. Apply some soldering flux to the exposed end.
4. Heat the exposed wires and apply solder. This is call tinning and will help when you are attaching the wires.
5. Cut the heat shrink tube about 1/2" long, you will need two. Insert the heat shrink tube to both wires that is to be soldered.
6. Solder the wires together by applying heat and attaching the wires when the solder melt.
7. move the heat shrink over the soldered area and use a heat gun to heat the tube. It will shrink and provide insulation as well.
**If you don't have soldering experience, you might want to take it to an experienced technician. Bad solder or poor insulation can cause expose wires and poses an electric shock hazard!
Jul 09, 2014 | BonJour Power 1800 Grill And Griddle...
I can not turn off the sleep mode on my LG Flatron monitor W2361VG-PF
This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). Open the monitor (snaps apart, no screws) and gently tug on each wire individually. One of them is causing the problem. You can replace the harnesses, try to fix them, or solder new wires directly to the pins.
Feb 16, 2013 | LG FLATRON W2361V 23 inch LCD Monitor
Power supply was cut
you can buy a new power cord or you can use another wire to replace the cord. just buy the same size then you will need to remove the rear cover to access the internal. and then the old cord must be removed from the ac terminal pin and the assembled wire with plug that you buy can be replaced. you can directly re soldered the end of the ac wire at the pcb for ac supply.
Aug 16, 2012 | Mitsubishi WD-57732 Projection Television
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
SONY KV SW 212 M80 Screen sowing pin cushion distortion. Screen is squeezed on the side and the side is curved inward.
Hello
Its pin cushion distortion circut had some trouble with it. There is an Ic and one transistor wich controls the pincushion effect. In most cased the trasistor that fitted on a heat sink, will have loose soldering at its terminals. this transistor will heat up during working, and repeated heating an cooling will make solder terminal loose contacted and it is normal fault. locate this transistor, very near to the LOT, resolder its solder terminals by applying a little more solder. It is best to resolder most of the surrounding solder terminals of high watt resistors, without making any solder bridge in between the solder points. If these does not helps you, replace both the IC [an eight solder terminal one, small IC] and the pin out transsistor described earlier at the same time. this will solve your TVs problem. OK.
May 22, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Trying to wire a 56 for a tristar 120. any ideas?
I think you are talking roadking 56, take the end of mike apart, you will need a 4 pin mike end,solder,steady hand,or small clip vise like I use,it takes just a little dab of solder for each wire,don,t over do it,trim each mike wire one eight inch back,slide the mike end on the cord,do not forget the plastic insulator,then solder the white (audio) to pin 1. then solder the shield and red together to pin 2,then solder the black (receive) wire to pin 3, then solder the blue (transmit) to pin 4. Then put it back together. ..hope this helps..
Mar 28, 2010 | Radio Communications
My rca output cord is cut...dothey sell a
Finding replacement parts for anything but technics seems to be difficult. However, if your familiar with soldering or have a friend who can, if you open these tables, you'll notice that the RCA cables are simply hard wired directly to the board inside the unit. You can take any RCA cable and solder it to the same posts if your careful when you strip your wires.
Sep 25, 2009 | Stanton STR8-80 Turntable
Light indicator is on
Try changing the battery, if it doesn't help, some possibilities are:
- dirty contacts or a broken wire on the footswitch
- a broken wire from the distortion output to the output plug
- a broken wire elsewhere in the unit (e.g. potentiometers or rotary controllers)
- a bad input / output level or other potentiometer or rotary controller
- a burnt out component (a bit unlikely, but possible, and it could be anything)
- a bad connector contact inside the unit
- a bad pin solder contact on ANY of the components inside the unit (wires, connectors, switches, jack plugs, resistors,variable resistors, trimmers, diodes, capacitors, transistors, ICs, etc.)
Broken wires / badly soldered pins need to be resoldered, but if there is damage to any of the components, they wil probably need to be replaced.
I hope you can find out what it is.
regards
3rq8 (Triarcuate)
Jul 26, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Power cord on flat iron broke
This is a very common problem. Only way to fix it is to replace the cord, which is not all that easy. You'll need TWO regular philips screwdrivers (size #2) plus a couple of little ***** philips screwdrivers. And a soldering iron, solder, and heatshrink.
Start by popping off the two plastic covers on the hinge area. Sometimes they break: they're not really necessary anyway. Use the two screwdrivers on the screws on each side of the hinge: one will eventually come loose. Take the screw out, then use a screwdriver to push out the hinge pin. Keep track of any washers that might fall out. Carefully remove the big spring, and lay the two halves of the iron out flat. On the control side, there are several screws that hold the covers on: remove those carefully. If the cord is the kind with the swivel thing, you'll have to take out all of those parts. There will be two wires going from the cord into the circuit board: sometimes they are attached with tiny screws, sometimes they are soldered. You have to solder a new cord onto those wires.
You can buy replacement cords at most hardware stores, or steal a power cord off another (broken) appliance. Two-wire cord is preferred: flat irons don't use a ground wire.
Cut the power wires in the flat iron: they are usually blue and brown. Brown goes to the black wire on your replacement cord, blue goes to white. Strip the wires carefully, slip the heatshrink on, solder, then slip the heatshrink over the repair and heat it to seal it up.
Now the hard part is trying to secure the new cord, since it doesn't fit the way the old one did. I usually put a big zip-tie on the cord, which is then captured when you put the covers back on.
Once the cord is repaired, you can re-install the covers. Don't tighten the screws too much, they are really easy to strip out. Carefully insert the legs of the spring into each half of the iron, then hold them together while you slip the hinge pin back in: it's a little tricky. Then use the two screwdrivers again, this time to tighten the screws. If the plastic covers aren't broken you can snap them back in if you want.
See? I told you it's not that simple. But since a new iron is, what, $100, it's worth a try.
Good Luck!
chris
Jul 24, 2009 | Oster 76076-010 Hair Trimmer
Cut one of my wires on the harnest
Hello jonesb37,
If there's enough of the wire left on the plug, you can simply solder and heat shrink or use a crimp connector to put the wire back together. If it's cut too close to the plug, then your best solution is to not use that particular wire at all. Connect directly to the appropriate pin or use a pair of "quick disconnects".
Hope this helps.
Jun 02, 2009 | A D S Car Audio & Video
Altec Lansing ATP 3W Computer Speakers Logo
399 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
