Question about Garmin Nuvi 350 Car GPS Receiver
Garmin nivi 200 won,t turn on
When charger is pluged in conection is very loose. and no power
  • sherriitorma Sep 16, 2009
    My Garmin nuvi 200 will not stay on. Said battery was low, however, I had it connected to my power source in my vehicle and the 'things' red light came on. Never installed new maps, Please help
I bought a Garmin Nuvi 350 dtd Mar 10, 2008 and purchase "lifetime updates" June 2009, now my GPS will not turn on even though I plug it into my power source. Appreciate advice on getting my GPS working
Posted on Sep 06, 2009
  • Garmin Master
  • 2,130 Answers
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Posted on Aug 21, 2009
How do you shut the garmin nuvi 200 down I can't get it to shut off
Plug it to your power charger (connected to the el-net, of course). After the map loading has completed and you can start using it, unplug from power. A dialog box will pop up and ask you either to turn it off or to continue using it on. Choose to turn it off.
You will not be able to turn it completely off as long as it's connected to either a computer or a charger.
or you on/off push button is not working and needs to be repaired.
On my nuvi 200 the push button is a bit loose, and it easly turns on when I carry it in my pocket. Some adhecive tape will keep the button in place.
Aug 05, 2010 | Garmin nuvi 200 Car GPS Receiver
When plugging into car outlet Garmin 200 goes into computer interface mode
You have to use a car charger with sufficient power capacity for your Nuvo 200.
I've used a mini USB car charger that came with my e-trex, but it works only some times when I do plug/unplugging during map loading (manipulating the computer mode setting). So, I bought a HTC mini USB care charger, and know the problem is solved. Another alternative is buy from Garmin Store, the type they recommend.
May 30, 2010 | Garmin nuvi 200 Car GPS Receiver
Have a phone charger 12 volt that fits and charges the nuvi 200 but with it plugged in it wont show anything but a computer and nuvi on screen. unplug and it works but only for a while til needs a new...
thats because the phone charger is wired different to the gps charger , u need a genuine charger, if when pluged into pc it takes longer to charge, best to have gps turned off while charging from pc..... if it still does not work/ hold charge battery in unit gone , caused by being in active for over 3 months
Dec 29, 2009 | Garmin nuvi 200W GPS Receiver
well if the plug is not making contact it cant recharge. you need to have it repaired and that may well be costly as it will require a new motherboard. Parts are no longer soldered or repaired The motherboard will be repalaced and the basic board is ^$90 the labour 1.5 hrs o 2 hrs minimum at $95 I am sure you will be able to buy a new model for the same cost
Aug 01, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 260w wont turn on. I used a charger that it wasnt used to and the whole thing just shut down. It wont turn on i tried the origanal charger, i tried pluging it into my computer, i even tried...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
May 31, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
No screen when device is powered on
my garmin 250W behaves like its conected to pc while conected to lighter-charger in my car.
May 24, 2009 | Garmin StreetPilot C330 GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
316 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
