Question about Necchi Sewing Machines
My needle won't pick up the bobbin thread. - Necchi Sewing Machines
    Problem Solver:
  • 16 Answers
Make sure needle is not in backwards. Groove of the needle to the front. If that is ok you may need a ball point needle for knits.
Posted on Aug 02, 2009
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Feb 06, 2016 | Sewing Machines
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
I THINK I've followed every instruction and tip regarding threading my machine and bobbin, but the needle won't pick up the bobbin thread. It just comes up as it went down, without the loop fr
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
Jul 24, 2012 | Singer Sewing Machines
Elna lotus
try cleaning under the needle plate & in bobbin area for loose threads or lint
try using a new needle--make sure the needle is inserted correctly in the needle holder
try rethreading the machine top & bobbin
if you try all these suggestions & the machine still won't pick up the bobbin thread then it's possible that the machine is out of time & would have to be retimed at a sewing machine shop
Mar 02, 2012 | Elna Sewing Machines
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
The needle won't pick up the bobbin thread? Seems
I think you mean the shuttle is not picking up the top thread. There are many reasons why this can happen. The best way to find out which is to leave the cover off the bobbin compartment and turn the machine slowly by hand while watching things happen for a few cycles - best to have a piece of material in place as well (but not in your line of sight).
As the needle begins to rise, the top thread should form a loop for the shuttle to pick up. If no loop forms, the needle could be too fat for the thread, the thread could be sticking to the needle, the pick-up arm could be out of time (unlikely), or the thread tension could be wrong (or the machine not threaded correctly).
If a loop forms, but the shuttle does not pick up up, the needle could be bent (take it off and roll it on a flat surface),or in backwards (loop forming opposite to shuttle), or the material (or your manner of feeding it) causing the needle to be deflected away from the shuttle. On some machines, it is also possible to loosen a clamp and move the shuttle closer to the needle, but obviously that is a last resort (unless it has come loose or been forced away).
There are other possibilities, but usually it's the simplest thing. Try changing the needle?
Jul 27, 2011 | Elna Sewing Machines
Sewing Machines Logo
67 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
