Question about Dryers
Dryer shuts off on E-1 code..Lint trap has been cleaned as well as vent hose and vent riser to outside.
    Brigadier General:
  • 4,088 Answers
Check for brisk air flow at outlet of vent hose (hose disconnected). If weak, remove lint screen and retry. If now has brisk flow, clean screen in hot water and detergent.
Posted on Aug 01, 2009
What is fault code 6 mean?
Hi Darrell, The link below is about how to trouble shoot and fix your dryer.....I hope this helps.....CHEERS..
http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
The most common causes for an electric or gas dryer to stop drying or heating is:
1. The dryer lint screen (lint trap) has not been cleaned (poor or restricted airflow).
2. A clogged or kinked (bent) dryer air vent hose (inadequate or no airflow).
3. Drum has stopped turning, broken drum drive belt.
4. Overheated or bad motor (possible thermal overload).
5. Thermal fuse or thermostat (could be caused from dryer air vent hose lint buildup)
6. Heating element burnt out.
7. Loose electrical plug or power socket.
8. Other mechanical issue, fault or malfunction.
Mar 31, 2016 | Fisher and Paykel DGGX2 Dryer
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
My dryer is leaking water
When your dryer spins to dry, water will start to collect at the vent, vent hose and lint trap areas. Make sure to fully remove the vent hose and lint trap and clean both of them out fully you may have to purchase a new vent hose. Make sure you secure both of these parts in after cleaning this should fix the leaking problem along with keeping your house firesafe
Oct 17, 2013 | Kenmore Dryers
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
Maytag dryer will not restart immediately after drying a load. has to cool down
try cleaning out your dryer vent. Remove your lint trap and use a flexible wire brush to clean deep inside, then remove your dryer vent hose and make sure all lint is clean from the dryer side of the vent and the vent hose all the way to the out side vent.
Sounds like it may be clogged with a build up of lint
May 23, 2012 | Dryers
My dryer isn't drying like it used 2, I have 2 run it a couple times on a cycle 2 get the same effect i used 2 get with 1 cycle. lint trap is clean,lint hose is clean vent also?
Check your vent hose. You probably need to get the vent system cleaned out. It sounds like you have a restriction in your vent line.
Aug 18, 2010 | Dryers
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Run for about half the cycle than stops. can restart and it will finish cycle.
Hi and welcome to FixYa. I am Kelly.
When a dryer runs for around 30 minutes and shuts off it has reached the maximum operational temperature allowed and is most likely being shut off by the high limit thermostat. This is a safety feature built in to keep from causing a fire due to over heating.
This overheating condition is usually caused by lint buildup in the following areas.
1. The outside dryer vent exit is blocked with lint
2. Flexible vent ducting has lint build-up inside
3. The lint filter in the dryer is restricting airflow
4. The lint filter trap area has a build up of lint restricting airflow across the lint filter.
5. The blower fan / blades / ducting have a lint build up causing low air flow.
Do a tedious insepction for lint buildup and all of the ducting areas that you have access to without disassembly.
Make sure to clean as much of the lint out of the areas that you can see. In the process of cleaning DO NOT use sharp objects to try and free the lint.
If you have to... sacrifice a coat hanger and bend it in half so that it is U shaped to assist you in clearing the lint in stubborn areas.
If you really want to quickly rule out the outside ducting... you can disconnet the Vent hose / duct from the rear of the dryer and then dry a load of clothes. If it does not shut off you know that your external ducting is where the problem lies. Just make sure to reconnect the vent / hose ducting after the test. (Over time can make a large lint mess)
One other thing to check is the dryer door catch to make sure it is not getting weak when the dryer is hot allowing the door open switch to kick off the dryer.
Thanks for using FixYa!
Kelly
Mar 02, 2010 | GE DBXR463EBWW Electric Dryer
The cycles have stopped heating. We have replaced the thermol fuse twice now in two weeks. Noticed when I touch the button to start a cycle, the readout is saying to check filter. Where is that? I'm...
Go outside and look at your flapper valve. Here is another news flash the lint filter can be clean but the air ducts in the dryer can still have lint build up in them. Pull out the lint trap also then using a flaishlight look underneath and around the lint trap area for lint build up. If you don't see anything there remove the rear vent hose and look both into the dryer and into the vent hose. Most likely you find either a kinded vent hose or lint buildup somewhere other than the lint trap itself. If you do find the source just do not use anything sharp to attempt to remove the lint. A bent metal coat hanger or a very large zip / spot ite works great for this task. Hopefully this will resolve your problem. If not post back and we can go from there.
Jan 14, 2010 | Dryers
Dryer Problem
SHUT OFF THE BREAKER to the unit then open the panel (3 Screws) that is in between the washer and Dryer you will see your venting hose ther remove the flex vent pipe from the exh duct closes Turn back on the pwr and run a load in the dryer see if it drys ok if you wil need your vent to the outside cleaned out
Jan 23, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Dryers Logo
98 people viewed this question
Top Dryers Experts
