Question about Compaq Armada M700 Notebook
3 solid LED lights after replacing hard drive
  • 104 Answers
Remove the cd dirve and chek it ,if it start good.you must change the master/slave on hdd bye replacing the jumper and ,,,
Posted on Aug 01, 2009
Why my light status indicator next to the battery About the hard disk is not blinking anymore?
the indicator shows the activity of the hard drive - heavy constant use is a solid bright indication down to none when idle with various level of illumination and flickering at all times.
Aug 30, 2014 | ASUS K50IJD2 Notebook
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
Western Digital Essential 1TB flashing white light & not responding. When you plug it in it you get a solid light, it spins for about a minute to two minutes & then the white power led starts...
hi i had the same problem, this is what i did. turn off the power supply and smack it about a bit then try it this should work!
i swear it worked for me, i think my kids must have dropped it which stuck the drive smacking it realised it.
Jun 22, 2010 | Western Digital My Book Essential 1TB...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor external Hard drive not recognised on any pc
Hi cimbom76,
Sorry to hear of your problems. The following is taken from the Seagate (they own Maxtor) website at :-
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&thread.id=192
For Maxtor Basics and Personal Storage 3100 and 3200 drives, there may or may not be an LED on the power supply, but the light on the drive should usually remain solid during normal operation, while powered on.
1. But if the power supply does have an LED on it, isolate the problem by connecting the power supply into a power outlet without the hard drive connected to it. If the LED blinks in this configuration, the power supply is faulty. Please contact Technical Support for replacement information.
2. If the LED remains solid, connect the drive. Once it is connected, turn the drive on. If the LED begins blinking, the drive has an electronic failure. Please replace the drive. You can create a warranty replacement order to replace the unit.
From what you have said i'm afraid it sounds like there is an electronic failure of the drive. I haven't followed the process through but they do offer a Data Recovery Service at :-
https://services.seagate.com/index.aspx?lng=en-us
There is an online form to fill in or you can telephone
020 7432 4619 to talk to a Data Recovery specialist.
I hope this helps and I hope that you can recover your pictures and videos.
Mark.
Apr 12, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor OneTouch III 500gb
One hard drive failure mode is a power circuit short. Contact MAXTOR support on their web site for a possible warranty replacement. BTW, SEAGATE owns MAXTOR now.
Feb 24, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Compaq Armada M700 Notebook Logo
49 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
