I have a vizio TV monitor, plasma I have red vertical lines on the screen. Seem like the lines start on the left side and end up on right side. Please advise.
  • 1 more comment
  • jsc5035 Aug 01, 2009
    I have vertical lines on my plasma tv can you help
    lI said the vertical lines start on the left side of the screen and the same vertical moves staying vertical to the right side of the screen. Thus the left side does not have lines anymore because the have moved to the right. I started with one line and now have four. I do not have directtv I have cable. The problem does not go away when I play dvds.
    I have a plasma tv 50" I have vertical lines on the screen started with one line I now have four
    Brigadier General:
  • 4,090 Answers
Requires a chip replacement for the vertical lock.
Posted on Aug 01, 2009
    Brigadier General:
  • 8,619 Answers
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly. Turn off the TV for 3-4 hours and turn it ON and check if the lines appears gradually, if yes then its the demagnetizing circuit that has gone bad or else it's the STK IC that needs to be replaced.
If you have repair knowledge or can deal with soldering, desoldering components on the TV board then you can replace these IC's. You'll also need to replace the 2 resistors next to the IC's.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Aug 01, 2009
    Hi
    As advised earlier if the lines appear again then its the demagnetizing circuit that has gone bad or else it's the STK IC that needs to be replaced. If you have repair knowledge or can deal with soldering, desoldering components on the TV board then you can replace these IC's. You'll also need to replace the 2 resistors next to the IC's.
    Thanks
    Rylee
    Sergeant:
  • 246 Answers
You didn’t tell what model, is it a plasma TV? And you said it was a vertical line, but from left side to right side???
If it’s a vertical line, you need a new panel.
If it’s a horizontal line, check the ribbon cable connection first (open the back cover, on your left hand side). Or you may need to replace the Y upper(or lower) driver board, depends on the location of the line.
  • xscrewdriver
    xscrewdriver Aug 01, 2009
    You can try to clean and reconnect the COF (matches the lines location on the bottom). Mostly the panel is bad, no repairable.
  • xscrewdriver
    You can try to clean and reconnect the COF (matches the lines location). Mostly the panel is bad, no repairable.
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
Multiple vertical white lines
hi,
As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty.
You can find these boards on the following link.
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrlbt-xl-eax35683901-ebr35855501/
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrrbt-xr-6870qsc107a-6871qrh073a/
If you need any more assistance feel free to contact me through fixya.
Ajin
Dec 12, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
May 13, 2009 | LG 50PX4DR 50 in. Plasma TV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
P2 42HD - Picture OK on right half ... vertical bars & black on left side
I just got quoted $705 from the Vizio certified repair partner. Nice. Nice and way too expensive. I may as well buy a new TV instead. It certainly won't be a Vizio. They told me a I needed a Y systainer, C systainer and a right-driver board.
Lame. I'm trying to find something local.
May 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Oct 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Red line on screen
Hope this makes sense.
Sep 29, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
