Question about JVC AV-27D305 27" TV
Volume turns down
My tv has started turning down the volume as soon as it is turned on. the volume box stays on the tv for minutes after it reaches zero. volume does work but as soon as you take your hand off the button starts going back down. took the batteries out of the remote nothing has worked
  • enasni Nov 25, 2007
    it has now changed from the volume to the channel change but the volume works fine for now
  • 934 Answers
It's probably a tact switch problem, something we call in the industry awindex syndrome. The tact switches, depending on the ones effected, can turn the tv on/off by itself, channel +/- at will or in your case control the volume.
Tact switches are not expensive to replace but a bit difficult to get to if you're not trained. They are at the very front of the board - looking from the back - and some disassembly may be necessary to take the main board out.
A reputable shop wouldn't charge much do fix this problem, switches are about a dollar a piece.
Good Luck
Posted on Nov 25, 2007
  • William Rayburn
    William Rayburn Nov 25, 2007
    It's no doubt tact switches.. I think you'll find that surrounding temp plays a role in what's being affected.
    Good Luck!
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ... > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Jun 27, 2015 | Emerson Televison & Video
Tv turns itself on and off
IC pin is dry in Micropro. IC
Jun 10, 2009 | Televison & Video
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Aug 28, 2008 | Sony STR-DE445 Receiver
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Volume Issues with Television
toshiba 35a44 I had in shop would not turn on initially,when Qa01 was replaced I was able to turn tv on, but after a couple of minutes volume went all the way down, vol display bar on screen and power and menu keys would not work, remote control function did not mater. after replacement of QA02 mpu no results. desoldered volume down and up keys and sprayed chassis with flux remover on both sides of chassis and sumerged vol keys in alcohol solutions for 10 minutes, restored them in chassis and the problem was corrected. QA01 and QA02 did not had to be replaced there was a contaminant problem on solder flux that was causing the problem. kbzon
May 11, 2007 | Toshiba 35A44 35" TV
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
JVC AV-27D305 27" TV Logo
223 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
