Question about Frigidaire FEF366 Electric Kitchen Range
Oven heats and does not stop at set temp i think that the temp sensor is bad how doi test this part?
    President:
  • 1,714 Answers
The thermostat bulb could be covered with spilled food and not sensing correctly. Check visually and make sure it's not touching the side of oven.
Sensor is the tube on the bottom of pic
Posted on Aug 01, 2009
Oven not heating properly themrador rdfs30qw
If the unit will heat, but the temps are off, then you may have a sensor issue. You can test this with a multi-meter.
Here is the part to order in case you find it bad.
Nov 30, 2012 | Kitchen Ranges
Oven won't heat accurately
Brad, your right on track. But I'd look toward the sensor first (The computer only does what the sensor tells it to do). I'll need the model number to find part numbers to help you further. The model number is on a sticker located on the oven body behind the lower drawer. It'll start with 3 digits then a decimal point the more digits (xxx.xxxxxxxx).
Sep 27, 2007 | Kenmore 96222 / 96224 / 96229 Electric...
We have a Whirlpool gas range model SF379LEKS that was purchased new in 2004. The oven heats up at first but then stops heating, even though the display says it's still on. There are no error codes. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 03, 2011 | Ovens
Oven will not heat i set the temp , turn it on,
Hi
Daniel
Aug 31, 2011 | Bosch HGS 255 Gas Kitchen Range
My oven will only reach 275 degrees even when the setting is at 400 or more. The broiler works fine. Are there heating elements that have gone out, possibly?
Hi
Daniel
Aug 02, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
My oven takes a very long time to heat up, and never really achieves the set pre heated temp
Hi
Daniel
Aug 01, 2011 | GE Eterna EGR2000EMBB Gas Kitchen Range
No power to upper oven 'bake' heating element.
Sounds like you have it figured, need to spend some moola..........
You can ohm out the sensor to the oven should be about 1100 ohms at room temperature.((the sensor is the little rod with two wires attached to it sticking in the oven, as temps change resistance changes which is read by the board) The upper and lower oven sensors are probably the same,you could just swap them to test, but probably not necessary,might also be confusing if you do not do a lot of testing on a regular basis. Remember to unplug unit for safety.
The bake element if it was not bad should be about 20 ohms, bad would read open........
Feb 21, 2010 | Maytag MER6772 Gemini Electric Kitchen...
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
Top Oven Stops Working
Sounds like a bad sensor for the oven here is the link to the repair manual to help you out
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Feb 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire FEF366 Electric Kitchen Range Logo
77 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
