Question about Casio Sea Pathfinder SPS2011V Wrist Watch
Casio illuminator, w-94h
Hi. I really need an expert here. I recently replaced a cr1616 battery in my watch and everything looks fine except it no longer makes beeps of any kind. I did not know how to unclip the old battery so I while battery side (6 clips to remove) then uncliped the battery clip from the other side. a tiny spring came out. There are only two hole it could have come out of and neither work (bring back the beep).
Thanks for your help.
Tommy V
tvowell@hotmail.com
There is a tiny spring that must make contact with the back cover plate when you screw it back on. If the spring is missing, the piezoelectric buzzer will not work. The tiny spring is located toward the upper right in this photo of a Casio W-94H watch, directly underneath the "C" in CASIO that is etched in the metal. Note that the word CASIO is upside down in the picture, so if you can't see the picture for some reason, the hole for the tiny spring would be directly above the "C" in CASIO.
Posted on Feb 01, 2009
I remember having to reset something using tweezers once the battery was in, making electrical contact.
Posted on Oct 14, 2012
  • rayali
    rayali Oct 14, 2012
  • rayali
    rayali Oct 14, 2012
    Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds.
I did have that problem. I just kept taking it apart and purring it together again and it eventually worked. Make sure that he back of the case is going on the right way. Also reset the watch. I think that there is a reset hole. That spring that you mention I think must make contact with an uninsulated part of the watch back.
Good luck.
Posted on Dec 03, 2007
I have a casio pathfinder model 2273 and the light went out. I changed the batteries, but still no luck. Everything else seems to work just fine.
Hi Jennifer
Two possibiities here one is electronic, unlikely but possible, and one mechanical that you can check.
When you changed the batteries did you notice internally the location of the button that turns the back light on? If you pressed the light button, did the button or a spindle move forward towards the body of the watch? did you notice a contact? or nothing pressed against anything?
When changing the batteries you would have click open the battery holding frame. This frame or internal back plate has around the light button a little piece of metal, like a finger that gets pressed by the button towards a contact in the body of the watch. This finger suffers metal fatigue and quite often looses its springiness or snaps altogether and loses it ability to make contact between the frame and the EL plate that illuminates the back of the watch.
If you are missing this contact perhaps you could buy a replacement plate from Casio. Can not advise as to the costs of doing it yourself or sending it to Casio. It is fiddly job.
Hope this helps
Nov 27, 2016 | Casio Watches
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Which replacement battery do I need for the backlight for casio aw 43
Casio AW43:
clock battery - SR920W
backlight battery - CR1616
Nov 05, 2009 | Casio AW43-7E1V Wrist Watch
What type of battery goes into Casio G shock MTG900, Module 2638
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Jan 22, 2009 | Luminox 3102 (Size: ) Watch for Men
Casio illuminator
Hi, release the small screw and turn left or right remove old battery and replace new one .
Feb 03, 2008 | Casio Databank DB35H1AV Wrist Watch
Casio Illuminator w-94h
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Battery issues,......
Hey all, here is a site that has good instructions on how to change the battery in your G-Shock watch. Sounds like you are suffering a low batt problem.
http://forums.watchuseek.com/showthread.php?t=20217
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
regards
Graeme
Jan 05, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio Databank watch
The replacement battery may be defective.
Nov 08, 2017 | Casio E-DataBank DBC3101 Wrist Watch
Casio Sea Pathfinder SPS2011V Wrist Watch Logo
3,571 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
