Question about Polaris Pb4 - 60 Booster Pump
Screaming Motor Just rebuilt pb460 and now motor is screaming. What do I do
    President:
  • 1,714 Answers
Check end covers. you might have put the bearing in a bind. Loosen covers and tap on nice and straight. Could be fan on end too. Check for rubbing signs.
Posted on Aug 01, 2009
Screaming noise coming from motor gets louder as rpm changes gears sounds like something screaming
if not alternator ,power steer pump,air con ,water pump \
serp belt tensioner or idle pullys
check crank pully is not running out of true
could be serp belt squeal
replace the serp belt
Mar 11, 2017 | Cars & Trucks
My dyson dc24 brush bar will not turn and there is a very loud screaming noise coming from the Hoover
Something has jammed the brush roller and the screaming sound is the motor shaft trying to move the stuck drive belt. The vacuum will have to be disassembled to find and remove the jamming material.
Oct 23, 2016 | Dyson Vacuums
I have a remanufactured lincoln impinger 1000 gas conveyor pizza oven which I believe was converted to a fast bake 1450 model and the main fan motor on the back is screaming.
If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Apr 29, 2014 | Lincoln Ovens
Main fan motor is screaming
Sounds like a dry roller bearing or shaft. If you can remove the fan unit and replace the lubricant or grease, your fan will work again as new. Most of them work in the same principle.
97a8e2c4-648d-4062-80a1-469c2350898f.gif 4e8fd9b2-8f17-40fc-9586-c9234d0d8ea7.jpg
Vacuum motor screaming
look at all the pipe and unblock them
Dec 25, 2013 | Oreck Vacuums
Heat makes a screaming sound - only comes on when on high, air does not come on at all - A little advice and help needed. THANKS
The screaming sound is the blower motor bearing. the fan speed switch controls the grounding side of fan motor once on high it grounds the high speed fan relay. so lower speeds goes through blower motor resistor. this may be burnt out do to bearing is screaming tight to shaft creating a larger ampere draw that burnt it out.
Nov 13, 2013 | 1997 Chevrolet K1500
A O smith part 7-177896 pool pump screaming
bad motor replace whole unit if overheating ruining rest of pump
Jul 26, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
My motor will not crank. i have full power but the motor does not budge i only hear the starter screaming i looked in my exhaust side of the head and my valves look find. the car just turned off on me...
Starter screaming-not engaging fly wheel
Valves look fine-leave them alone
5th gear car turned off-fuel system, ignition system, emissions
control system, quite a bit can go wrong here. I would seek
professional help.
Jan 16, 2011 | 1997 Honda Civic
Pump motor making noise but not screaming. Does
Usually this is one of the bearings in the motor. I don't know of a good shop in your area. Check pricing carefully. Sometimes it is only a few dollars more to buy a brand new motor.
Jul 09, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Polaris Pb4 - 60 Booster Pump Logo
210 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
