Question about Dell 966 All-In-One InkJet Printer
Broken Belt I put the belt back on an it was loose
    Scholar:
  • 96 Answers
Check the belt path, there is a tensioner somewhere in there that will tighten the belt.
Posted on Sep 25, 2009
2007 Saturn aura has been making a rattling sound over the last month that has gotten progressively louder. It sounded like it was coming from around the serpentine belt area. On my way to work today, the...
Obviously one of the pulleys is loose or the tensioner is faulty.
I would check all of the pulleys before trying to put the belt back on.
You should find a bad bearing or broken spring.
Aug 04, 2012 | Cars & Trucks
Maytag neptune dryer belt off and loose
If belt is not broken, then the tensioner is not routed properly. Generally belt comes around drum, then around tensioner pulley then on motor pulley. Tensioner is spring loaded, so you need to pull up on tensioner to get belt around motor. Good luck.
May 05, 2017 | Maytag MDE9700AYW Neptune 174 Electric...
The serpentine belt on a 2.4L is VERY loose after alternator replacement. Can I tighten it or is the tensioner or belt dead?
I think you are on the right track, suspecting the tensioner. It should spring back after you release it. There is a pretty heavy spring inside, it may have broken.
Nov 21, 2011 | 2000 Chevrolet Cavalier
Power steering pump came loose and the surpentine belt came off. How do you fix the pump and tighten it back and also where do you loosen the pulley to put belt back on.
if the pump was not damaged when it came off you will have to buy the right size bolts to mount the pump back in place unless the bolts have broken off in the holes in which case you will have to remove the broken bits from the holes b4 you can bolt the pump back up.
As for the belt tensioner you will need either a socket with a long handle arm or if it has a half inch square hole in it you can just use the handle by putting the square end on the handle into the hole of the tensioner and pull down on it while you place the serpentine belt in place b4 letting the pressure off the tensioner
Jun 13, 2010 | Cars & Trucks
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
How do you open the dryer to fix the belt
First before you you raise the top, open the cover on the back by the motor and let the belt loose from the motor pulley unless the belt has broken. If it has go to the lid. Slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. Three are usually two screws, one on each side holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on.
Jun 06, 2009 | Maytag MDG6000 Dryer
Broken Belt--kenmore 70 series dryer
it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Dell 966 All-In-One InkJet Printer Logo
140 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
