Question about Boating
My handheld Jandy PDA 1.37 is giving me a reading of 1600 ppm and a general fault indication. The folks at Leslie's Pool Service test the water at 3300 ppm (three times) and tell me I need to reset/recalibrate my system. I've had the pool four years - no problems until now ... How do I reset/recalibrate the system?
  • 10 Answers
SOURCE: Too much salt in pool (4,100)
the leslies employe is right the only way to get rid of the high salt level is to drain the water i would say drain a 3rd and fill pool and check salt level some salt genarators can not make chlorine at high salt levels or when the water is cold
Posted on May 19, 2009
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
co7196
  • 3433 Answers
SOURCE: Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Posted on Jun 01, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
  • 4 Answers
SOURCE: I have a jandy aqualink RS PDA. It will not
System locked up. Handheld is frozen at WAITING screen. Microprocessor is locked.
Here is what you do:
1. Turn off power to the system.
2. Disconnect battery at the Power Center and turn on power.
3. Reconnect the battery and reset time and date.
4. Thank me.... You are welcome... BadWally sends.
Posted on Aug 30, 2011
Jandy screen backlight won't light
go into system set up find PDA and turn on the back light it will give 2 5 or 10 min choices
Oct 31, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Jandy PDA not showing water temp
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
Mar 02, 2013 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
How do I fix a PDA with general fault message? What can can suh a reading?
general fault is the aqua pure either not enough salt or too much salt check salinty or the sensor or cell needs cleaning or replacing
Nov 05, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Indicates "waiting" and will not show menu
try turning off rs system turn off pda turn rs system back on then turn on pda reboot
Oct 03, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Button on jandy pda 8265 broken
See this thread:
http://www.troublefreepool.com/how-to-fix-your-jandy-pda-for-15-t52166.html
May 13, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
May 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Boating Logo
385 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
