Question about Toshiba 50H71 50" Rear Projection Television
Picture off center vertically
The picture is about 2 inches low. The bottom of the picture isnt visible.
  • 934 Answers
Mattrat,
You probably need a simple vertical adjustment in the service menu - - easier said than done. I would personally call out a tech and have them do it, because there are some elaborate save procedures in this unit that could cause you a real mess if you foul it up. Besides, a service-call isn't that much for a reputable shop.
If you need help finding one try: http://www.nesda.com/locator/state_search.php
Bill
Posted on Nov 25, 2007
What is the differance between a class 2 safety vest & a class 3 safety vest & is there a class 1
Class 1 safety vests are for workers in low impact areas, where traffic flow does not exceed 25 mph and where personnel are working a good distance away from it. Parking service attendants, delivery vehicle drivers, and sidewalk or roadside maintenance workers are examples of jobs who would qualify for a class 1 safety vest. These vests should have a mandatory minimum of 155 square inches of reflective tape. Dimensions of the reflective tape can be either 6.46 linear feet of 2 inch tape or 9.39 linear feet of 1 3/8 inch tape. The reflective stripes should be around the middle in a 360? stripe and above each shoulder. Vests should be either a safety yellow or safety orange color.
Workers who are involved in jobs where there is heavier traffic are required to wear a Class 2 vest. Jobs that require workers to work in areas where there is poor visibility due to weather will also need a more reflective Class 2 safety vest. Class 2 vests will have a minimum of 201 square inches of reflective tape that is 2 inches in diameter. Dimensions of the reflective tape can be 8.373 linear feet of 2-inch tape or 12.2 linear feet of 1 3/3 inch tape. Examples of jobs that require Class 2 vests are airport baggage handlers and ground crew, forestry workers, high-volume parking or toll-gate personnel and law enforcement personnel. Reflective stripes will be over the shoulders and round the middle in either one or two 360? horizontal stripes.
Jobs that require workers to be the most visible are ones that put personnel in close contact with heavy traffic. High risk jobs include accident site investigators, emergency responders, railway workers, utility workers, and survey and flagging crews. These workers will often be close to traffic exceeding 50 miles an hour, so it is important for them to be as visible as possible. Class 3 safety vests and garments must have a minimum of 310 square inches of reflective tape that is 12.92 linear feet and 2-inches thick. Class 3 garments also provide more coverage to the arms and legs than do class 1 and class 2 safety vests.
Feb 28, 2015 | Work Safety
Sharp aqous picture error
You Vertical Problem can you go to advance settings to adjust
vertical Size? Or center the picture
Nov 02, 2012 | Sharp LC Televison & Video
I have 20 inches tv there is a sound but no picture,it so dark picture
Since you say dark picture visible, then : Brightness control setting!
Check the resistors on the neck PCB. If you find the resistance value of these resistors high, replace them.
If No EHT is found then also there won't be a picture visibility.
1. Open the back cover and see whether you can observe a faint filament glow in the picture tube neck, close to the picture tube socket.
If there is no glow E H T circuit failure.
2. If the glow is observed check picture tube grid voltages grid no. 2. as said above.
( the points referred above are all for technical people)
Oct 15, 2010 | Televison & Video
Why isnt my stem for the handlebars long enough to reach through to tighten it at the bottom?
Your handlebar stem has to be inserted at least 2 1/2 inches or else it can snap and it is tightened at the stem bolt at the top. Why are you trying to tighten it at the bottom?
Sep 25, 2010 | Falcon Cycling
I have thin white lines that run across the top of my picture. They are only visible when picture is full screen. The wide screen picture (with the black areas at the top and bottom) do not show this. The...
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Aug 10, 2009 | Televison & Video
Change refrigerator door handle
Hi, look at the ends of the handle and see if there is a cap you can remove. It looks like there is a screw behind the end caps.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Bars on screen
you have a blown circuit on the motherboard of your tv. the only way to fix this is to send it to the manufacturer (hopefully you sent in the warranty). or take it to a tv repair shop.
Feb 21, 2009 | NEC PlasmaSync 50MP2 50 in. Television
Two green lines on bottom left corner
Sounds like a convergance issue. I would have a tech set the convergance for you if you have not done it before, it can be tricky and you could make worse.
May 11, 2008 | Toshiba 65HM167 65" Projection Television
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 50H71 50" Rear Projection Television Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
