Question about Whirlpool WFW8300SW
What is f27 error code, washer does not spin - Whirlpool WFW8300SW
    Scholar:
  • 51 Answers
F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following:
1. First, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2.
2. Check the drain hose and make sure it is not plugged or kinked.
3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
4. Check/Clean Drain Pump Filter of foreign objects.
5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off
7. Check the Pressure switch for proper operation.
Thank You for contacting Fixya.com
Posted on Aug 02, 2009
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
What is F27 error code?
The F27 error code indicates an overflow condition. If the washer is overfilled and continues to fill with water, this would indicate that you have an inlet water fill valve that is stuck open. If you unplug the washer and water continues to fill the tub, then the inlet fill valve assembly will need to be replaced. Make sure that the drain system is properly installed according to the installation instructions. An improperly installed drain system could result if siphoning of drain water back into the washer.
Check to see if the drain pump is working properly to pump out the water. When the F27 occurs, the drain pump will run constantly to pump out the water. The door will remain locked. Shut off the water supply faucets behind the washer. If water is not being pumped out of the washer, you could have a clog in the drain pump or drain hose. The following link of a previous answer provides advanced troubleshooting for a drain problem:
Why won't my HE4t washer drain?
If the washer is not overfilling and the F27 remains even after the washer is drained, then it is likely that you have a failed pressure switch. A failed electronic control board in the washer could also cause this problem. To access the pressure switch, unplug the washer and remove the top panel. Screws at the very back of the top panel secure it to the washer. Remove these screws and pull the top panel slightly back and then up and off of the washer. Sometimes, you can reset a stuck contact in a pressure switch by tapping on it with the handle of a screwdriver. I you cannot reset it, the pressure switch will need to be replaced. If you have the same problem after replacing the pressure switch, you will likely need to replace the control board in the washer.
Aug 19, 2014 | Kenmore Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
Check
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool WFW8300SW Logo
308 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
