Question about Ruud UBHC Air Conditioner
THE EXACT SAME ISSUE. THE CONTRACTOR IS NOT BEING ACTIVATED.
THE CONTRACTOR IS NOT BEING ACTIVATED. i REPLACED THE RUN CAPICITOR AND IT STILL IS NOT ACTIVATING THE OUTSIDE UNIT. I CAN PUSH THE CONTRACTOR DOWN AND EVERYTHING WORKS, BUT AS SOON AS I REALEASE IT IT STOPS WORKING.
THANKS
PAUL
    Problem Solver:
  • 5 Answers
Then the contactor is not receiving the signal to pull in from what ever control unit sends the signal.
Posted on Aug 01, 2009
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All...
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Sep 02, 2010 | Heating & Cooling
Friend said the capicitor went bad and they are
Could be true, but often it is cheeper and better to replace cpu. Otherwise you still have an older computer, that got repaired.
Sep 25, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Aug 14, 2009 | Heating & Cooling
A/c won't shut off have to use breaker
sounds like your run capacitor has failed you can find it if you remove the top cover there is a side acess were there is a lot of wires coming out remove that acess there should be 3 capacitors 1 fan 1 start 1 run make sure to turn the braker off before checking the capicitors remove the run capicitor & check for shorts
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Delta Drill Press motor stopped running
I tried the model number listed and didn't find just a capacitor, but I would think that you would be able to find it at a local electrical supply house, one that specializes in service to the contractor, take that one with you and they should be able to match it up. If not give me the exact model number and I will try and find one online for you
Mar 14, 2009 | Delta DP350 Shopmaster 1/3 Horsepower 12...
I HAVE A LOCK FLASHING ON MY ARCITEC NORELCO RAZER .THE RAZER WON,T TURN ON.
Try holding the power button down for a few seconds, this turns the lock on and off. Hope that helps, Nick.
Dec 28, 2008 | Norelco Arcitec Electric Shaver with Jet...
Acer Monitor 1706
I replaced the 470uf 25v capicitors and this fixed the problem. I had 2 monitors exactly same with the same problem and it fixed both of them.
Apr 21, 2008 | Acer AL1706AB LCD Monitor
VS19E Capicitor
you can ask from all radio shack.
Apr 03, 2008 | Computers & Internet
Ruud UBHC Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
