Question about Whirlpool LEQ9858L Electric Dryer
RUNS AND HEATS UP BUT THEN QUITS LIKE IT OVER HEATED
MY DRYER RUNS GOOD AND HEATS UP FINE BUT AFTER A WHILE IT WILL STOP, AND WHEN I PUSH THE START BUTTON IT MAKES A BUZZER TYPE NOISE. AFTER IT SITS A WHILE, IT WILL AUTOMATICALLY START UP AND RUN UNTIL THE CYCLE IS
FINISHED OR UNTIL IT HEATS UP AND STOPS AGAIN.
ANY CORRECT ANSWERS TO MY PROBLEM OUT THERE?
    Brigadier General:
  • 4,088 Answers
Check for good air flow from wall end of flex hose. If weak, remove the lint screen and retry. If now ok, soak the lint screen in detergent and hot water. Hard to tell if this is the correct answer.
Posted on Aug 01, 2009
Car runs perfect then starts missing real bad then stalls
Not unusual for fuel pumps to begin to fail once they are heated up from running. First thing in the morning pump is cool, then as you drive, it heats up and begins to lose pressure. After sitting a 1/2hr-1hr, it may start again and run fine for a short time and start to act up again. Had similar problem and found good fuel pressure when tank and pump cool, but lost pressure once vehicle driven a distance and pump heated up. The hotter the weather, the shorter the distance I could drive. If you can somehow set it up to have fuel pressure checked when it starts to act up, that would certainly help confirm if fuel pressure is the culprit.
Jan 10, 2013 | 1996 Dodge Stratus
DRYER RUNS SOMETIMES MID CYCLE DRUM QUITS TURNING BUT STILL HEATS UP COMES BACK ON AFTER A FEW MINUTES
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 26, 2011 | GE Dryers
Dryer heats up for a few minutes and then quits but dryer still runs
Hello
When the dryer heats for few minutes and then it won't work it means that the thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this fuse for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Speed Queen AES28AWF Electric Dryer
Kenmore dryer heats at first then quits
You may have a bad thermocouple. The thermocouple is what "tells" the control unit that the flame is present. If it doesn't tell the control, the control turns the gas off to prevent an explosion.
Jan 02, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer runs when first started, quits halway through drying cycle.
High temp. limit is probably at fault and will need to be changed.
Jul 13, 2009 | Whirlpool Dryers
Not heating
sounds like you have weak coils. I have had this many times in the past and changing the coils has always seemed to work....they work fine when they are cool, but once they heat up they stop working.
Nov 18, 2008 | Kenmore 73952 Gas Dryer
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Whirlpool LEQ9858L Electric Dryer Logo
125 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
