Question about Garden
What should be the gap for the ignition modual for a 122 blower
  • 154 Answers
I believe its about 30
Posted on Aug 03, 2009
Ignition module gap setting
look up the manual on the stihl site
it tells you this detail
Dec 05, 2013 | Stihl Magnum Br600 Professional Backpack...
Adjust ignition timing gap
CLOSE! put two pieces of paper against the Flywheel, then put the Coil in place loosely. rotate flywheel until magnets hold the coil to the flywheel ( with paper in between) then tighten
Nov 21, 2013 | Troy Bilt Tb320bv Spring Assist Blower/Vac
How to set the ign. modualer on leaf blower
You have to set an "air-gap" on the ignition module between the legs of it and the magnets in the flywheel. Use a standard size business card as your "feeler gauge." Fold it in two. Place it in between the legs of the module and the flywheel. Turn the flywheel until the magnets line up with the coil legs and let the magnets draw the module into it. Tighten the hold down screws. Remove the business card. Your "air-gap" is now set at approximately .010" Closer is better, wider is not.
May 21, 2011 | Poulan 25CC Gas BlowerVac
Im looking for an on-line firing order diagram for a 1997 land rover disco with a 4.0 v-8
Telephone: Fax: VAT Registration No.:
Notes Specified value Measured value
Ignition system
Ignition coil Make Bosch
Ignition coil Type 0 221 122 392
Ignition coil supply voltage + with ballast V 11,0
Primary resistance Ohm 0,67-0,82
Firing order 1-8-4-3-6-5-7-2
Distributor (ECM) Make Lucas
Distributor (ECM) No. 42583A
Contact breaker gap/trigger air gap mm 0,20-0,35
Cylinder layout
Manufacturer: Land Rover Model: Discovery (90-98) 3,9 Engine code: Output: 134 (182) 4750 Tuned for: R-Cat Year: 1994-98
© Autodata Limited 2007 14/05/2011 V6.410-
8 7
6 5
4 3
2 1
looking from front of disco
May 14, 2011 | 1997 Land Rover Discovery
My 90 geostorm fires when it wants to. have replaced all fuses n replaced coil checked and cleaned cap n roter extreamly frustrated whats up with it?
intermittent spark usually caused by failing ignition module in distributor cap, but first check air gap on pick up coil--should be 0.008-0.016 in. (0.2-0.4 mm). If air gap is good, replace module. If air gap is bad, adjust and see if problem resolves.
Nov 29, 2010 | 1990 Geo Storm
Bignition modual gap spec
The gap is to be set at 0.10, usually a business card works well for this.
Have fun.
Nov 12, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Yukon denali blower will not turn off after car is off
The blower motor modual has shorted out. I'll guess and say it has auto air? The modual is by the passengers feet. There is a close out pannle it is held in with some 7mm scerws then you can have acess to the modual, it is next to the blower motor.
Oct 11, 2009 | 2003 GMC Yukon Denali
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
