Question about Microsoft Xbox 360 Console
Same problem, dots and lines, bluriness...
Would a intercooling fan help solve the problem?
  • 114 Answers
Before doing that, try a normal fan and position at the rear.........if this works, you know the solution.
Posted on Aug 01, 2009
White lines that are constantly on will go away for a few seconds then pop back up.. Mitsubishi 73" model number WD-73640
You need to replace the 4719-001997 DLP Chip. this should solve the issue.
This chip can be expensive so look around before you purchase. This is a common problem with these TVs, both white lines and white dots. You can find out how to replace the chip by going to this website: http://www.fixyourdlp.com/2012/09/04/solve-the-mitsubishi-wd-73640-white-dot-problem-with-a-new-4719-001997-dlp-chip/.Hope this helps
Feb 27, 2013 | Televison & Video
05 golf 1.9D TDI engine code BKC
Check the seals on the intercooler, for oil to get in the pipes means that the seals are damaged and its loosing compression
Jul 16, 2008 | 2005 Volkswagen Golf
My 98 subaru legacy made a big sucking sound and ever since then the turbo hasnt worked and there is a strange rattle around the intercooler area,
TAKE LINES OF TURBO TO INSPECT THE TURBINE (FINES) ON BOTH
INTAKE AND EXHAUST ALSO LOOK FOR LOOSE LINE AT INTERCOOLER
OR DEBRIES FROM TURBINE IN THAT AREA IF SO DO NOT RUN
REPLACE TURBO --AIR FILTER---INTERCOOLER---TAKE ALL PIPPING AND CLEAN
TAKE OFF AT INTAKE OF ENGINE AND CHECK FOR METAL MAKE SURE CLEAN OF DEBRIES OR THE MOTOR WILL SUFFER DISENTEGRATION FOR SURE
Apr 19, 2011 | Subaru Legacy Cars & Trucks
Can i use a intercooler if my fanis no workin properly in my ps3
It is not recommended to simply rely on the intercooler fans. Since they are not cotrolled by the main board they do not adjust for correct operation. The intercooler fans are the to get fresh cooler air around your system and to help remove some of the heat generated.
Mar 21, 2011 | Video Game Consoles & Games
Manual focusing on d5000
Most professional photographers use spot focussing...just the center dot. You focus on the subject...hold the shutter button half-way and recompose..press the rest of the way.
Jul 29, 2010 | Nikon D5000 Digital Camera
Over heating
This is easy, Order a new xbox 360 fan off of ebay. Open up your console, and replace the parts. It's very simple, you just plug it into the motherboard.
Also, DON'T use an intercooler. There have been stories that say because it runs off of the Xbox360s power source it can lead to the RROD
Mar 03, 2010 | Microsoft Xbox 360 Console
I bought a NYKO intercooling fan and the plug from the xbox 360 elite will not go into the fan receptacle is there a specific intercooler for the elite?
Microsoft has two different power connections for the Xbox 360. I do not recommend the use of the Intercooler. Believe it or not, it actually prevents air from circulating and increases the temperature of the 360!
For cooling I always recommend the fan modification. I have written a free guide showing you how to do this, no soldering skills required!
Here is the guide.
Hope this helps! Let me know if you have any questions.
Dec 29, 2009 | Nyko Intercooler for Xbox 360
Help change fan belts on Mitsubishi pajero nm 202 mod can`t undo pully nut is it left or right handed thred
First job is to remove the 4 bolts securing the Intercooler, Its not totaly necessary to remove, but makes it a lot easier to get to the pullies.
Remove the 4 Bolts and move the Intercooler to the left hand side of the engine
Loosen off the locking bolt on the centre of the pully and then loosen the adjuster bolt until belt slackens
Loosen off the forward facing locking bolt and then loosen the adjuster bolt (Hidden behind the top hose) until belt slackens
You should now be able to remove all the belts and replace as required.
On refitting the belts adjust as required and then do up the locking bolts, refit Intercooler and check all connections (you wouldn't like the intercooler fan to fail
Its as easy as that, Good luck and not be held responsible for any 'misfortunes' in carry out the job like breaking out in to a sweat.
Apr 13, 2009 | 2002 Mitsubishi Montero
Blury pictures
change the resolution setting in setting. and also you can adjust diplay bright ness and contrast for bets view & pics .thsi will solve the problem. Thanks Sangita
Jul 08, 2007 | Samsung Digimax S500 Digital Camera
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
