Question about Saeco Magic De Luxe Espresso Machine
Saeco magic when i press the button for coffee, only 1 or 2 light will burn and a small amount of coffee comes out. if i keep the button pressed, then also stops the machine by 1 of 2 light. There comes enough coffee in the prullebak
  • bansheracer May 11, 2010
    What happens when you press the other 2 coffee buttons? Do you have any other lights on the machine?
  • 2,039 Answers
Look like or brew unit is block if you didnt change the kind of cooffee or play with the grinder to fine of a grind normally the grinder should be at 5 or 6 the brew unit the top part with side pipe remove the 2 screw be carefull there a little spring and rubber seal and a little ball of glass remove notice how it goes so youll be able to put back after removing those part clean the hole all the way to the to the filter it should do the trick let me now how it turn out thanks pierre
Posted on Aug 03, 2009
Why does the descaling light keep coming on?
When the machine is on, the
warning light
switches off automatically, by pressing the steam
selection button for at least 5 seconds
May 03, 2014 | Saeco Magic De Luxe Espresso Machine
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Royal Professional at work and when each of the three coffee size buttons are pressed you get three different sized coffees. I have just bought a new Saeco Royal professional for home and...
Hi
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Apr 05, 2011 | Saeco Royal Professional Espresso Machine
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Coffee does not come out when I press the small coffee button. The coffee grinds but water is not injected. The large coffee button works.
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Nov 01, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
No coffee coming from machine
Can you make a cup of water or you can only get a half cup?
I think it can be your flowmeter in the machine that has to be replaced.
Aug 02, 2008 | Saeco Magic De Luxe Espresso Machine
Won't make coffee
Could you please advise how I obtain a manual for a Saeco Magic deluxe
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
107 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
