Question about Innovage Touch-Panel Phone 1507102
Bought innnovage lcd scteen phone lost direction sheet for setting timew etc. can I get on line guide
  • 3 Answers
I just found my copy, email me at tishapt@sbcglobal.net and I will scan and email to you.
Cherrik
Posted on Aug 07, 2009
Recover deleted photos
You can recover deleted photos from mobile phone with if you follow this mobile phone photo recovery guide
Recover deleted files from mobile phone
the guide helped me before. Easy to follow and works well. hope that it helps you too!
May 06, 2013 | Nokia E72 Smartphone
Tip
Comdial 8024S Reference Manual Download
Download Comdial 8024S Reference Manual
Models: Impact 8024S, 8012S, 8324S, 8312S, 8324F
Would you like to review the features of the Comdial 8024S LCD Speakerphone?
Have you lost your Comdial 8024S LCD Speakerphone Reference Manual?
Would you like a digital, searchable, pdf version of the Comdial 8024S LCD Speakerphone Reference Guide?
Follow this link
(& click FREE) to download a pdf version of the Comdial 8024S LCD Speakerphone Reference documentation.
I hope that helps.
____________________________________________________________________
Comdial 8024S Station Manual Download
on Jul 13, 2010 | Comdial 8024-S Impact 24-Line Phone
I860 will not print a 4 x 6 photo on a windows 7 pc. It gives a message that I have installed the wrong paper. It only wants to print full sheet size photos. I installed the canon add on module drivers and...
Set Envelopes Correctly Before setting envelopes, press down on all four corners and edges of the envelopes to remove curls and bends, as well as any air contained.
Note: The flap of the envelope should be straightened if bent. If the envelope is curled, hold the opposite corners and gently bend them in the opposite direction. If the leading edge of the envelope is puffed or curled up, use a pen, etc. to press the envelope flat and sharpen the crease. (Press the envelope completely flat, working from the middle to the edge.)
i80_envelopes_2.gif How to set envelopes:
  1. Set envelopes to the right side of the sheet feeder. Set envelopes with their longer side vertically and the flap either at the bottom or on the left.
  2. Pinch and slide the paper guide until it firmly resets against the left side of the stacked envelopes.
    Note: The maximum number of envelopes that can be loaded is five.
    <1> Sheet Feeder's right side
    <2> Paper Guide
  3. Set the paper thickness lever to the left.
    <3> Paper Thickness Lever
    Note: Remove the printed papers from the paper output slot cover before five sheets have been ejected.
Also How do I enlarge or reduce my printing size?
Nov 07, 2010 | Canon i860 InkJet Photo Printer
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Cannot find right code for our direct tv remote to run my recently purchased sanyo hd tv
if you have the codes sheet provided by direct TV for the remote, depending on the brand of TV there would be several sets of possible codes if you lost them the going to the direct tv site on the web will more than likely allow you to download an electronic copy of the user guide which you can then print out.
Dec 07, 2009 | Washing Machines
How do i fax using a canon mx860 all in one printer?
Press the FAX button, open the document tray and align the paper guides for A4 size paper.
Place the sheets in the document feeder, facing up, first text line towards the machine, first page on top. The machine will beep. Adjust the paper guides.
Enter the phone number, and press the black button. The fax will be sent with the default settings.
Refer to the user manual as to how to change settings (it's quite straightforward from the menu, anyway).
Nov 04, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
T-Mobile Dash White Screen, Not Re-setting!
If your screen is white then the lcd cable probably is not seated all the way.
Follow this guide and just reseat your lcd cable instead of replacing the lcd screen:
How to Replace T-mobile Dash LCD Screen
Dec 02, 2008 | T-Mobile Dash Smartphone
How to save fax numbers
press Function
72
set
1 for ONE TOUCH NUMBERS
set
press 01 on the soft pad
enter fax number with the DIALING NUMBER KEYS
set
enter name with LETTERS on the soft pad
set
continue with 02, 03, 04 etc.
when done press stop.
press Function 67
set
cut out directory sheet on dotted lines and put under the mylar sheet on the soft pad.
press Function 62 set to print out the list of one touch numbers.
Nov 19, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Instructions for settings on Canon MP-610 printer{ OK, HOME, ettc.
What setting on the MP610 do I use to print on transparency sheets
Jun 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
We have lost our manual to our phone & need to reprogram our side phones off of the base phone so we can have use to all the side phones that came with our phone package. Right now the only phone we...
I have both a user guide and spec sheet, pdf format if you are still interested.
Email me at cayz at verizon dot net (no sense giving spam bots anything to chew on).
Apr 24, 2008 | GE Lands Phones
Lands Phones Logo
70 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
spiritsoul
Level 1 Expert
Computer Repairing
Computer Repairing
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
