Question about GE Spacemaker JVM1640SJ Microwave Oven
Need help figuring out microwave installation above stove
Just purchased new stove and microwave to put above stove, however we do not have a cabinet above the stove to attach it too....Any suggestions what we can do....desperate...thanks
  • maggief Nov 26, 2007
    would like to avoid building a cabinet...microwave meant to be above stove....
    sorry, i was unaware that ratings count..can it be reversed? thank you for the idea...sounds intersting,doable and unique idea.
  • GE Master
  • 9,098 Answers
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Posted on Nov 25, 2007
  • William Miller
    William Miller Nov 26, 2007
    If you don't want to build a cabinet, then maybe a shelf on the wall or hanging it on chains from the ceiling might be other viable options.
    By the way, you rated my request for further information before I had full information to actually propose a solution.
    Not sure I understand that... that really hurts my rating here.
    I do try to be thoughtful and helpful, regardless of the circumstances.
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
How to install over stove microwave
the microwave has a metal hanger that needs to be secured to the wall, in the right spot, then you need to drill holes into the cabinet above the stone,1 will be for the cord, which i use a 1/2" hole saw for that, then you will need drill bit a little bigger than the diameter of the screw, if the microwave is new it will have a plan-o-gram with step by step instructions or you will have to be good at measuring with tape measure to put holes in the right spot
Feb 24, 2011 | Whirlpool Microwave Ovens
How far out does a microhood sit from the cabinet. My cabinets are 12 inches and the microhood I want is 16 deep. Also it will be 19 inches above my stove.
Don't know right off the top of my head, but the installation instructions should tell the min and max height from the stove. If they don't you may want to contact an electrician to find out.
Mar 29, 2010 | Kenmore 62622 Microwave Oven
How do I install a replacement Frigidaire over the stovetop microwave - professional series, without removing the cabinet above it? I need to know how to best remove the existing microwave.
Remove everything from the inside of the microwave, (such as glass tray). Unplug the microwave, probably in the cabinet above. There are two screws in the cabinet above the microwave, near the front, that supports the front of the microwave. The back is hooked on a mounting plate attached to the wall behind it. An assistant is a good idea though this can be accomplished alone. It is best to move the stove out, if you are going to try alone. Please be carefl there is considerable weight to support here. Support the front of the microwave while the two screws are removed in the cabinet above. Slowly tilt the front of the unit down until you can pull the cord out of the bottom of the cabinet. With the front still tipped down, lift the back from it's support and remove it.
Jul 18, 2009 | Microwave Ovens
We have had custom cabinets made for our kitchen and have installed a microwave above the stove and it is to high for my wife, She is 5'4" tall and can hardly see in the micro wave. The carpenter doesn't...
you will also need to consider space between the stove & microwave, but you could go back to your cabinet company and have them make you a dead panel that matches your cabinets for the face side of the microwave. then you will also need three other pieces 1 for each side and 1 for the back! if you want to drop the microwave down 12 inches have your panels cut 12 inches! have your carpenter block in and attach panels, go to a fastner company with 1 of the bolts that the microwave came with to hang it from the cabnit and find or order bolts the compensate for the depth in which you you have your panels built!
May 31, 2009 | Microwave Ovens
How do you remove a microwave above the stove
Take the glass tray out and unplug it. Remove the 2 or three phillips screws in the top of the cabinet going into the micro. They should be towards the front. Hold up on it while removing screws. When all screws are out, let it tilt forward and lift it up off of the hooks. Some require help, so be carefull and put blankets on your stove to set it on when it first comes out.
Apr 10, 2009 | Kenmore 63762 Microwave Oven
Sounds easy...but
Installing one of these between two cabinets and supported by the one above it is a pain ..but even worse if you don't have the installation directions. If you are relatively handy and have some carpenntry experience, I'll walk you thru the way I install them. First off, I assume you are installing this above a stove and betwwen two wall cabinets.. You need to do a little preparation work first. locate the wall mount bracket and you should have a packet of hardware ( primarily two long screws that will be used to support the front of the micro from the cabinet above) If you have all this.. you'll need to determine if you are going to vent the micro back into the room or plan to vent it outside. The simplest is to vent it back into the rook thru a charcoal filter but if you are going tovent it outside, you have two choices.. one is to vent it up thru the cabinet and outside via ductwork that you buy..if the microwave oven is being attached to an outside wall then it is easiest to vent it straight out the back ( i say this because you have to orient the blower in teh configuration that you are planning to use) Let's assume you will be venting this back into the room ( that's the easiest ) and move on.. The wall mount bracket supports the back bottom of the microwave oven when you secure it and the two long screws will be used to bring the front of the micro up against the bottom of the cabinet above it... I normally locate the wall studs and then buy and fit a 1/2 inch piece of plywood onto the wall where the micro will be mounted. The microwave will project out 1/2 inch further as a result of this plywood panel but.. you can use lots of drwall screws to the secure the plywood to the wall studs and then you can mount the wall bracket onto this plywood without having to worry about where the studs are and if it will support the microwaves weight. Mount the bracket onto this plywood piece. I will use drwall screws and add flat washers to them to provide additional support. Once that bracket is installed, you will need to figure out how you are going to provide power to the microwave. If you are replacing an existing oven then you will probably have a power fees inside the cabinet =situated above the microwave oven. If not, then you will need to provide a power feed for this. In the old days, most of these appliances were hard wired into junction boxes but nowadays, most appliances are treated as removable and all you will need is an outlet box in the cabinet above. I suggest you bore a hole large enough for the power cord plug to fit thru the bottom of the cabinet so that you can plug it in. The next part is the hardest to accomplish.. If you look at the top of the microwave oven, you should see two holes near thhe front and on top. Those two holes have floating captive nuts inside them that the long screws ( included in your hardware kit) will be used to snug the front of the micro up against the bottom of the cabinet above it.. The trick is to measure from the back wall out to where these holes need to be drilled in the cabinet above so that they line up. You can drill bigger holes than you need and use oversize washers if necessary. If this sounds complicated IS.. i have put many of these in and unless you are actually doing one, youhave no idea how involved this can be.. even worse with ducting to the outside.... I hope this gives you some tricks on how to install.. And um.. if you do get this all together, you will need some help actually putting it in place.. You'll need to catch the back of the microwave onto the tabs of the wall bracket and then feed the wire thru the cabinet while you lift the entire thing up to start the screws from the cabinet down onto the top of the microwave. I'm a big guy and have done these myself but it is not easy.. Hope this helps you.. Lastly, here is a link to the GE website where you can download the user manual and search their FAQ for install details ( in retrospect, I just should have given you that info)..
Hope this helps you...
Sep 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Aug 27, 2008 | Microwave Ovens
Maytag above the stove microwave not working
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 14, 2008 | Maytag MMV5165 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
248 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
