Question about Krups Small Appliances Espresso Machine
Krups km7005 water not heating nor hot plate
All other aspects work fine on the unit, do not have manual or information on this unit.
    Scholar:
  • 22 Answers
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbech, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Oct 19, 2009
I have a krups mk7000, quit working, changed filter, no water comes out and hot plate is cold, Jim
the thermal fuse has blown and needs to be replaced , if unit gets too hot it will blow it is very small possibly in heat shrink tubing crimped on the AC cord inside, need a test meter to check for current. need heat to boil water to rise to the filter and so on. these thermal fuses sometime are 2 check all in side the machine , can be replaced for about $8-10 dls us each @ Radio Shack should be 8-10 amps .187 diameter .625 length >^.^<
Mar 19, 2010 | Krups Coffee Makers & Espresso Machines
Why, within a year, will my Krups KM7005, not draw water through the filter and into the pot??? Nothing is blocking the flow. Perhaps the heating element is no longer working to prepare the water. The...
you are correct ? i hope the heating element must work to boil water through the machine and check for the thermal fuse hidden with in the in line cord inside the machine. check all with test meter on continuity selection for electrical flow. thermal fuse got too hot and save the machine ,but the element is not on ! thermal fuses are not resettable ..and have to purchase them at your local Radio Shack 8-10amp rating in cases. and about $ 8.00 us each >^.^< good luck, let us know ?
Mar 15, 2010 | Krups Coffee Makers & Espresso Machines
HOT OR COLD WATER IS NOT BEING PUSHED THROUGH THE PUMP
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Jan 12, 2010 | Krups Small Appliances Espresso Machine
A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
Dec 16, 2009 | Krups Small Appliances Espresso Machine
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
My Krups Grinder Brewer has stopped pulling water though the system. It just stays in the resevoir. Grinder part seems to be working fine.
The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 09, 2009 | Krups KM7000
Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
Oct 07, 2009 | Krups Coffee Makers & Espresso Machines
Krups model KM7005 water wont heat
Jun 02, 2009 | Krups Small Appliances Espresso Machine
Apr 10, 2009 | Krups Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
667 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
