Question about Samsung ML 2010 Laser Printer
Samsung ML 2010
After removing a paper jam the online/error ligh is on and nothing prints at all. It doesnt even attempt to print. What can I do?
  • Anonymous Jun 10, 2008
    I Cannot get my printer to print it only prints a blank sheet. I have tries to disconnect, shut off,
    Nothing works.
    Karen
  • anjoka May 02, 2009
    I've turned off the printer for 10-20 seconds and nothing worked. It has now been off for 3 days. When I turned it on, it still won't print. I've checked for jammed paper and everything else I can think of. What can I do now?
  • 3 Answers
It is the clutch relay and or driver on the board HVPS Q6 and or Q7. The clutch will not allow the gear to release. I have seen this and is most common problem.
Streak www.streak.asia
Posted on May 11, 2009
  • Mack Baxter Jan 30, 2011
    I can not find the Clutch relay-- Is it on the main Circuit Board at the back of the Printer?
    Thanks,
    Mack B
  • 186 Answers
First open all covers and make sure there is not another piece of paper stuck in the machine. Check under the toner cartridge. If you are sure there is no other paper stuck, try unplugging the machine wait about a minute and plug back in.
Posted on Nov 25, 2007
Try taking off the rear cover and holding down the plastic switch near the top of the circuit board. I have marked the location in the image below. When i was having trouble with this printer i just held it down towards the ground for around 10 seconds and it printed a test page just fine.
Posted on Dec 29, 2011
SOURCE:
Page is not loading during printing
Occasionally, paper cannot be load during a print job.
Some of causes include:
• The tray is overfilled.
• The front cover has been opened during a print job.
• Paper that does not meet paper specifications has been used.
• Paper that is outside of the supported size range has been used.
If a paper jam occurs, the On Line/Error LED on the control panel lights red.
Find and remove the jammed paper. If it is invisible, look inside the printer.
Note: U would find the complete instructions along with the screen shots in the below link
http://tinyurl.com/notloading
Best of Luck
Dec 05, 2010 | Samsung ML 2010 Laser Printer
The online light stays red and I can not print anything. what should I do?
check the toner cartridge. red light means there is an error in the printer. check for any paper jams. check paper tray settings.
Oct 01, 2010 | Samsung ML 2010 Laser Printer
I have a samsung ml 1740 & its not printing, I have an error/online light on red and it does not seem to beable to pick up the paper?
unplug then plug it in again. after u hook it up with the computer try turning it on and off before u start printing!
Aug 24, 2010 | Samsung ML 2010 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
Online error light nothing prints
I have a ML 1710 .Not my area of expertise but I took out the paper and could not see a jam. Took toner out , a little cleaning, plugged and unplugged from computer several times. I found paper jammed in the very back ,folded so tight nothing was showing. Mine has a back door and the paper is having trouble rounding the last bend and coming out. So I leave the back door open to get my copies. Green light on.
Feb 26, 2010 | Samsung ML 2010 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
My samsung ML-2010 JUST DOES NOT WORK ANYMORE!
Is it connected directly too the computer or to a network?
What it sounds like is that you are having a spoiler problem, the computer is intialized but its not getting the info to print. Or it could be a printer malfunction, something mechanical isn't working right in the printer. If you've removed the ink cartridge and replaced it, it could be out of place or not seated right. Other components could be locked up. If the light goes red could you tell us what the error message is? And have you looked at your user guide for information on possible errors?
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Samsung 2010 printer
Mine did the same thing, turned out to be an empty toner cartridge. The one that comes with the printer when you buy it only prints about 50 sheets before it dies.
Mar 13, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser printer
LSU means "Laser Scanner Unit". That is the part that actually "prints" the image on the drum before it goes to the paper. If the toner (not ink) cartridge is in good condition, then you need an Authorized Service Center to replace the LSU assembly.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
Samsung ML-1710P Printer Problem
Most probably you took one of the paper sensors out of place. Any printer technician can happily put it back.
Jul 24, 2006 | Samsung ML 1710 Laser Printer
Samsung ML 2010 Laser Printer Logo
896 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
