Here are the codes for your GE TV: 645, 742, 763, 531, 676, or 690.I have provided the instructions to program the DISH remote to your GE TV:AddressRemote to TV
While at the device location (TV, etc), point the remote at the device. Press and hold the device button on the remote (TV, Aux, etc). - All four mode buttons should light up
Enter the three-digit remote control code - The mode button (TV, Aux, etc.)you selected should light up
Ifyou are programming a code into AUX Mode, you must do the following beforeentering the device code:Press 0 for a TV (if TV code is 500, enter 0500)Press 1 for a VCR/DVD (if DVD code is 617,enter 1617) Press 2 for any other device (if device codeis 639, enter 2639)
Press the Pound (#) button - The mode button you are programming should flash three times
Press the large, red POWER button - The device should turn off
1.Turn on the component to be programmed, such as the television or DVD player. 2.Press the "Code Set" button on your Hitachi remote. The button is often located near the top with the separate component buttons. 3.Press the button for the component you wish to program with the Hitachi Remote(TV,DVD). 4.Enter the manufacturer's code for the component being programmed. The manufacturer's code can be found either in the Hitachi manual, the manual for the component being programmed or on the website of the manufacturer of the product. 5.Press the "Enter" button to submit the manufacturer's code. 6.Press the power button for the component being programmed. Make sure the remote is pointed at the correct component, and it should turn on if the program was entered correctly
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
go and buy another remote as this is the most useless waste of time when you keep getting the run around and no answers.what does it take to post a page with all the remote numbers on it they all come with the same page.
Select your remote model RCR311B from the pull-down list, then select the device your want to program, then select the brand and it will give you the codes....
