The roller stopped rolling. At first it was stopping and starting and then it just stopped all together. I took the cover off to make sure the belt did not bust; it was fine. I removed, cleaned, and reinstalled the roller and then it worked for a few minutes but then stopped again. Any suggestions?
This is what is happening with my vacuum. The roller stopped spinning and it smells like burnt rubber, but the belt is fine. I've only had it for seven months, and I can't afford to replace it. My last Eureka vacuum melted at the ends of the roller too, so I think this is a problem with Eureka's entire product line. I will never buy a Eureka again.
I Have the same problem, My vacuum cleaner kept smelling like the belt was burning. I would take it apart and the belt was fine. This has gone on for several months. Well tonight it did it again. It was not the belt it was the end of the brush roller (melted). I read one comment about why that is happening. I did not change the carpet setting so it is something else. I am having a hard time finding a part.
Comment by Guest, posted on Aug 28, 2008
Ours stopped working within 3 months of being purchased. Reading these comments was very helpful. I was going to see if it could be repaired, but now I am not so sure.
I am having the same problem with ours and it's less than 6 months old. First the belt broke, then we replaced it, then the brush roll locked up and melted at one end. This really sucks. We are going to order a replacement brush and if it happens again I am going to toss it and spend the money to buy a good vacuum cleaner that will last alot longer.
I have the same problem, one end of my roller just melted off. Worse yet, I have searched the net all day and can't find a replacement part. I'm beginning to think they build these things to break so you are forced to buy a new one. What a rip off! I have had mine just three months.
Was this solution helpful? Show your Appreciation by rating it:
What I can suggest is taking the cover off and taking off the belt. Then turn the vacuum on and see if the upper spindle the belt goes on (not the roller) is turning. I think it could be two different things, but I'm guessing your belt is slipping. They just get slick inside and don't turn the roller. You can clean the spindle and roller where the belt attaches (I recommend isopropyl alcohol and q-tips), also try cleaning the inside of your belt, but if that doesn't work try replacing the belt. See if that works.
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
I am having the same problem. My belt stopped working and my Vac is less than a month old! Like hell I am going to buy a new one when this one didn't even last a month. I gave away my old vac because I got this one for Mother's day. I loved my old vac.....this sucks.
My roller stopped rolling and the bearing at the end of the brushroller was melted. I just called Eureka with the same problem. The operator was very helpful. She said that this melting thing happens when people change the carpet height setting with the vacuum on. It must be off with the handle unlocked as if you were going to vacuum. If you try and change it with the vacuum on the nothing really happens, it just moves the knob and creates heat underneath and the melts the bearing and belt. To get a new brushroller go to Eureka.com., click on the parts/accessories tab at the top, on the next page click on the Eureka online store tab at the end of the first paragraph. THe click on the search tab onthe far bottom left. Type in 62228-3 in the search box and your part will come up. it should be 12.99.
I've had a similar problem, it kept smelling like burnt rubber and when I took it apart to check the belt noticed that the roller bar bracket had melted and it's not broken. I'm looking for a replacement right now. I bought mine less than a year ago but I can't find my receipt and never registered it, seriously if I knew this was going to happen I'd have just bought a Dyson since buying a new vacuum (+ the first one) would total a Dyson. ****!
I had the same problem after just 7 months. I took the roller brush out thinking that it might need cleaning. It was clean, but I noticed one of the bearings was seized up. I am trying to find a replacement roller brush, but I am not having any luck. Can anyone find a replacement?
I ran into the same problem. I took everything apart-(who in the world designed the screw holes?). I cleaned everything and reassembled twice. Nothing is broken or caught. The rollerbrush won't roll. My vacuum is 4 months old.
ya my vacum is doing they same thing i just bought it a mounth ago,i have never had a vacum do this. the roller want roll its stuck and theres nothing in it.
