Question about Amana ACF3355 Gas Kitchen Range
How to I remove the stove top on a jenn-air range scg20200w . I need to replace the control panel. I've taken the 4 screws off under the control panel, but it looks like I need to remove the stove top to get the front panel off. any help is appreciated.
  • skretmks Aug 01, 2009
    I can not seem to side the top forward or back. The owners manual says the top is not removable. but I can see two screws comming down from under the top that I need to take out in order to remove the front panel to get to the control panel out
    President:
  • 1,714 Answers
Try sliding the panel forward or (back) then lift it up to release.
Posted on Aug 01, 2009
  • Craig Butler
    Craig Butler Aug 01, 2009
    Yes, give that a try...
How do i replace touchpad on JGS8750ADS
here's a picture of it and a price http://www.repairclinic.com/PartDetail/Control-Panel/74005737/895120 it's the whole front panel,unplug it or throw the breaker if you can't pull it out all the way,open the oven door and look up,remove the screws going into the panel.on some you might have to pull the stove out a few inches and remove the front side trim pieces to get at any hidden screws and remove the side caps of the panel,pull off the knobs and that should be it,slide out the control panel,remove the clock assy. and ribbon and then reinstall it.http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Range-Parts/Model-JGS8750ADS/1266/0124250/M0603274/00001?blt=06&prst=0&shdMod=JGS8750ADS go here at the sears site to get a better view of the parts.hope this helps.
Dec 18, 2011 | Jenn-Air JGS8750ADS Gas Kitchen Range
How do you remove front panel on jenn-air sve47100
Make sure to dsc stove or be careful ... Open the oven door and look under the panel, tools that you will need are phillips screw driver and a 5 sided bolt head tool .... there's 5 screws and 2 of the other tool.
Dec 07, 2011 | Jenn-Air SVE47100 Slide-In Electric...
I have a stoves farmstyle 1100 df cream range cooker. I am having problems with the timer and have bought a new one but I need to know how to remove the top to fit it. The cooker serial number is 050564146
Hi.
To replace the timer control you need to remove the front fascia panel and the hotplate at top.
Before starting disconnect power and move the range forward.
To remove front panel you need to undo the 4 screws at the sides and to remove the knobs, then remove front panel.
To remove the hot plate you need to remove 4 screws at the back. There are also 4 screws at each side of the hot plate. You may need to remove the side panels to reach those screws. There is also an additional screw located behind the control.
Here a service manual for the range Farmstyle 1100E, which is similar to 1100DF. The disassembling instructions for top and front are at pages 62 to 64 of PDF (sections 4 to 6). Control board and touch pad are at page 67-68 (sections C and D of disassembling).
Service manual: Stoves Farmstyle 1100 1st.pub
Regards.
Ginko
Oct 07, 2011 | Stoves 1000DFDLm Gas Kitchen Range
I need to replace the hinge receptacles on a Jenn-air wall oven (WW30430PC). How do I access those parts?
The only way to replace the hinge receptacles is to pull the oven out of the opening. If you need parts you can get them on the link below. Also if you call the link below they will walk you through on how to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45883&diagram_id=28594572#d28594572
May 16, 2011 | Jenn-Air Ovens
Replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Jan 01, 2010 | Kitchen Ranges
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
Dec 26, 2008 | Jenn-Air JED8430 Electric Cooktop
How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Replacing control valve/burner valve switch
This just started to happen to ours too. It's because you can't get let water get into the valve/switch assembly. Ours got so much water in there that it was making huge sparks and flames which charred up the switches. You may have to replace the whole 5-burner igniter switch assembly. I think it's part number 74010753. To access, remove 2 screws under the front of stovetop. open Top oven door to access. remove the 2 screws that hold the gas valve assembly. Remove 2 screws out of each burner assembly. Remove the green grounding wire on the right hand corner of stove top. The stove top will come off revealing the 5 white igniter switch assembly which is all wired together in parallel. Remove the large metal panel on the rear. There are two wires that are off the 5-burner switch assembly that you unplug. Replace this whole assembly and the problem should be fixed. Hope this helps
Jun 18, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jennair gas stove
500 dollars shoud do just fine
May 22, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Amana ACF3355 Gas Kitchen Range Logo
699 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
