Refer to the drawing below and I will explain the connections. You have the nine wires as you described. First, you will not be connecting the SHIELD to anything, so set it aside. Now, the remaining 8 wires are split into 2 groups of four. You have +5V1, -D1, +D1, +GROUND1 on the first group. These wires will attach to the ODD pins 1,3,5,7 respectively (see the chart next to the drawing). Use the missing pin location to orient yourself to the EVEN and ODD pins. The remaining wires +5V2, -D2, +D2, and GROUND2 will go on the EVEN pins 2,4,6,8 respectively.
Hope this helps!
