Question about Kenmore Washing Machines
Clothes don't smell clean; how do I get my clothes to smell clean? Especially my towels.
    President:
  • 1,273 Answers
Go to YouTube, type in "smelly washer".....really. You'll find several tutorials there; one of them is what you need.
Regards, --W/D--
Posted on Aug 01, 2009
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clothes, especialy towels smell moldy no matter
Same problem here, heavy lime in the water, we had to change to Purex powder with Renezit. Problem is gone!
Jan 29, 2010 | Samsung Washing Machines
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Laundry
Same problem with my front loader. You have to make sure to clean out the rubber trap in the front regularly. it seems to collect alot of hair and plug the drain hole. also it helps to leave the door open when you finish washing to further reduce the stagnant water smell. Use fabric softener for the towels!
hope that helps.
Aug 02, 2008 | Kenmore Elite HE4 Electric Dryer
Disgusting odor
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
Mar 12, 2008 | LG WM2688H Front Load Washer
Clothes just don't seem to smell clean
We have the same problem with the 3200, I have run a cycle through with no clothes and adding bleach instead of detergent.
Seems to help some.
Feb 28, 2008 | Bosch WFMC 3200 Front Load Washer
Smely Clean Clothes
We had a similiar problem. It was mildew in the washer and in the fabrics. We ran two or three empty loads with some bleach added in, and we leave the door open so the drum dries.
The towels and clothes we hung out in bright sunlight. The UV rays kill the mildew.
Dec 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Washing Machines Logo
78 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
