Question about Tec RadiantWave Grill
Screws have sheered off at the heads on the TEC burner. Do I need a new burner, or can I simply replace the screws with new, better ones?
  • 57 Answers
Call TEC tell them your problem! they have a warranty on there grills for 8 or 10 years depends on which one you have!
Posted on Aug 24, 2009
What size and thread pitch (simply sheet metal?) are the 6 screws that hold the burners to the back wall?
Just use a drill bit set to check the closest size of the hole and purchase some sheet metal screws or self taping metal screws a size bigger.
Jul 04, 2014 | Grilling
Trying to replace igniters. is there an easy way to get to them to replace? or do you have to chisel out screws or easy out?
I know, it's a bear, once the grill is a few years old. Aside from that, you'd expect the R & D Dept to come up with a better way to attach the 'U' shaped burners, for a grill that is one of the most expensive ones on the market.
In any event, I found that if the screw heads are badly rusted, using an easy out or drilling the screw out, is about the only way to do it. If you drill it out, start with a small diameter bit and work your way up. Of course, you'll have to use a little larger diameter sheet metal screw to attach the new burner(s). I highly recommend Stainless Steel Screws, in case you ever have to replace the burners again.
Hope this helped you get them out. Please let me know and Happy grilling!!
May 28, 2011 | Dacor Epicure EOG36 (LP) All-in-One Grill...
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
customercare@grilltechs.com
Nov 06, 2010 | Tec Patio II Grill
We have a Charmglow 720-0234 5 burner gas grill. Replacing the burners that rusted out but can't get the screws out of the back of the grill that holds burners in place. Ideas?
yes. These screws are literally rusted in place. Begin by squirting each one with WD-40 Penetrating Lubricant. Let that sit over night so the lube will indeed penetrate. The next day the screws may back out, if not and you can get a pair of needle-nosed locking pliers on them, back em out that way. As a last resort, drill them out. Joe
Mar 18, 2010 | Grilling
Tappan stove model # 30-3053-23-02. How do I remove the stove top?
For Tappan stove model 30-3053-23-02.
Each burner (4) is mounted to the stove top with three 4.5mm hex screws. All 12 screws must be removed, which is easier said than done. In my case, of the 12, 6 heads snapped off. The other 6 heads had to be drilled out. The metal is very hard (tempered from long exposure to high heat?), so use a carbide/diamond high-speed drill bit (1/8" or 3/16").
The front corners of the stove top are each held by a clip. After removal of the burner mount screws (or heads at least), lift straight up on each front corner of the stove top to release the top from the clip. An alternate method is to use a screwdriver as a lever to pry the corner off the clip. Once released from the clips, the front pulls up, while the back is "hinged" (like lifting an auto hood). Using a stubby phillips screwdriver, unscrew one of the back hinges. At this point, the stove top can be lifted off.
If you are fortunate, the burners were unmounted by simply removing the screws. But if they broke off or had to be drilled out, it seems the best thing to do is just purchase new burner assemblies ($20-$30 each). In either case, also buy new screws specifically for mounting the burners.
Dec 22, 2009 | Kitchen Ranges
Large section of dual burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
How do i replace a ignition switch in a saturn sc2
Takes hammer and small long chisle or puch to back out two screws that have heads sheered.This removes assembly then has two 5.5mm screws retaining switch to housing.
Jun 16, 2009 | 2001 Saturn SC
Replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Jul 13, 2008 | Brinkmann Charmglow Stainless Steel LP...
Expensive TEC Grill Problem with Blowout After Ignition
HI nabber8391,
I have a TEC Pattio II. I have owned the grill for almost 10 years and TEC grills have a ten year warranty on many of the parts including the burners. The burners on my grill have a ceramic inserts. The pop and loud whooshing noises indicate the ceramic insert or the seal on the burner is "cracked". I have replaced both of the inserts and burners on my grill once about 5 years ago under warranty. I have one burner now that will not stay burning and I contacted TEC today regarding the problem, and I will replace the ceramic insert only under warranty. .
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE.
By the way, I paid $1400 for my TEC grill in 1999, but I believe the new TEC grills are better. I know I would not buy any other brand. One other thought, it is imperative that cleaning instructions are followed.
Jun 23, 2008 | Tec RadiantWave Grill
Install
Unscrew the screws on the back of your computer that hold the sheet metal sides on. Take both sides off then simply pop out one of the bay covers and install it next to your current drive. Or you can take out your old one and simply hook the cables up to the new one. Screw everything back together and you're all set.
I hope this is the answer you were looking for.
If you're better with off using a guide with picture you can use the link below for a more thorough guide with pictures included.
http://anewshop.com/dvdrw/install.html
Jan 23, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Open Questions:
TEC grill went BOOM and caught our house on fire. On Sunday, Sept 27, our TEC grill failed. We didn't know about the breaking screws. It had apparently flared up quite a few times, but we thought that it was just the meat catching when we opened the top up. On Sunday we were cooking a pork loin at about 33% gas levels across all burners. This should've taken about 30 minutes but we checked it after ten and found the loin was completely burnt on the outside and raw in the middle. We've been having bad luck with BBQ and couldn't figure out why. So we were going to put some steaks on but before that we looked and noticed the temp gauge on the lid was showing over 800 degrees!!! It was off the charts! My friend also noticed some flames leaking out the lid on the right side of the grill. He quickly turned all the knobs off and BOOM! Something blew and propane started venting freely from the tank. It shot a column of fire about 4 feet wide that engulfed the grill and rose to about 10 feet hitting the bottom of our back porch. It blew nearby floodlights and our porch started to burn. Extinguishers couldn't put it out. I screamed for him to call 911 and get the fire department. I told him to run inside in case the propane tank exploded. The flames were intense! I ran to a hose to try to put out the fire and was finally able to get it under control. What was left was a twisted, mangled grill and a LOT of fire damage to our home. I'm talking with an attorney today after she sees the damage. Luckily, no one was hurt or killed. Just a LOT of singed hair. I'm very angry that TEC isn't correcting this problem that's been plaguing homeowners for two years and the information that people have had did not bring some kind of recall at Lowe's. Needless to say, I can't repair the grill nor would I want to. I now need to rebuild one side of my back porch and re-run electrical and cable connections to melted flood lights. Yes, they actually melted in the heat. It appears to be the same issue I've read about in the 9 pages of this forum. Thank you so much for having this thread running. I hope that this helps others out there.
Sep 29, 2009 | Tec RadiantWave Grill
Tec RadiantWave Grill Logo
120 people viewed this question
Top Tec Grilling Experts
paulcarew
Treefrog15
Treefrog15
Gary Kenady
Gary Kenady
Are you a Tec Grilling Expert? Answer questions, earn points and help others
