Question about Mitsubishi WD-57732 Projection Television
How much for a new screen? - Mitsubishi WD-57732 Projection Television
    Brigadier General:
  • 4,090 Answers
Well you will need to donate more than 2 arms and 2 legs may be cheaper to buy a second hand unit complete
Posted on Aug 01, 2009
How do i replace the screen
Plug a new one in. if it's on a laptap you peel the edge around the screen off slowly(having bought a laptop screen beforehand) and from there you unscrew the old screen, take it out(mildly carefully)and unplug the video cord to the screen(VERY carefully as to not damage it unless you wanna buy a new one and rewire it to the base part which is a ***** to open up) and plug the new one in and make sure not to lay down the new screen or you'll **** it up. Screw the new one into place(make sure it's right side up, but if not you can fix that through stuff like alt+ctrl+arrow key) and click the trim back on.
If it's a tv style screen you unplug the video ****(generally red yellow and white cords in back) plug it into the new one and find a preferential positioning for it.
Tower screen then you unplug the VGA or whatever video cord you use and plug it into new one.
Phone or smartphone takes speciallized equipment, but if you wanna do it then you crack case off(turn the ****** off first) following the lines around the edges and then take screen off according to composition of the phone itself and put new one in except do it reverse of taking the otherone out.
Whatever screen it is good luck.
Oct 28, 2012 | Televison & Video
Tip
How to change boot screen in XP..???
1. First download and install Tuneup Utilities
2. Now click on Customize Windows -> Tuneup Styler
3. It'll open a new window. Click on "Boot Screen" link in left-side pane.
4. Now click on "Add -> Load Boot Screen From File..." option.
5. Select your boot screen file and click on "Install Boot Screen" button.
6. You can also create your own boot screens. To create new boot screen, click on "New Screen" button. It'll open a new window. Now click on "Search Local Drives" link and select the image.
You can also set the image alignment, borders, background color and progress bar position.
7. Once you finish, click on "Save boot screen" link and provide a name to your boot screen.
8. You can even see the preview of the boot screen by clicking on "Show large preview" link or by clicking on the image in Preview pane:
9. That's it, your new boot screen is ready. You can apply it by clicking on "Install Boot Screen" button.
on Jul 19, 2010 | Computers & Internet
JUST REPLEACED LCD R52 AND THE SCREEN IS BLACK
You replaced the broken LCD screen in your laptop with a new screen but it’s not working.
Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
You did some research and purchased a compatible screen, installed it into the laptop, turned it on and… The new screen is not working!!! What could be wrong?
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the backlight inside the old screen lights up, apparently the new screen has defective backlight lamp and has to be replaced.
Oct 14, 2009 | IBM ThinkPad R52 Notebook
Need to replace LCD screen toshiba p105-s6024. need instructions to remove screen
Hello
First of all, I assume that your new LCD screen is compatible with theold one. Different screens require different video cables. Make sureyou new screen is compatible with your laptop.
Use the link below for more details and instructions.
http://www.laptoprepair101.com/laptop/2008/09/18/you-replaced-broken-lcd-screen-but-the-new-screen-is-not-working/
Regards
PCmania
Sep 26, 2009 | Toshiba Satellite P105-S6024 Notebook
To replace broken screen on acer aspire 5735
First you need to get the right screen. Take out the screen by removing the rubber bumpers on the corners of the lcd bezel, then unscrew the screws that were beneath the rubber. After that you will have to pry slightly on the edges of the bezel to unsnap it and remove it from the laptop.
After that you will remove the screws on the sides the attach the screen to the hindges. On the back of the lcd it will give the model number, ebay is a good source for lcd screens. Once you get a replacement screen, you disconnect the cable on the back of the lcd and bottom, and then repalce the screen and assemble in reverse order.
Sep 01, 2009 | Acer Aspire 5735 Notebook
Need a replacement screen, its cracked any chance on getting a replacement, is it worth replacing?
Hey how are you!!!
What is your unit? If your unit is a laptop ou need to follow this.
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Fortunately, most newer LCD's have a different type of connector, without fragile pins inside.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no back light.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the back light inside the old screen lights up, apparently the new screen has defective back light lamp and has to be replaced.
Good luck
ICmanServer
Aug 14, 2009 | Memorex MM7000
Broken screen
Hey how are you!!!
screen-not-working-3.jpg Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
screen-not-working-4.jpg The video cable has to be seated properly, all the way down.
screen-not-working-5.jpg Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
screen-not-working-6.jpg OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Good luck
ICmanServer
Aug 01, 2009 | Acer Computers & Internet
Can i replace my Gateway laptop tft screen with a new lcd screen?
The screen resolution is a combo of:
  1. the screen's capability
  2. the video card's capability
  3. the driver's settings
If the above screen is made for this laptop (as it appears to be), then the settings you had should still be there.
Jul 29, 2009 | Toshiba LCD TFT Monitor
Need to remove lcd
Hello
These are the tips you should follow. This is my solution regards about my laptop problem.
You replaced the broken LCD screen in your laptop with a new screen but it’s not working. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible withthe old one. Different screens require different video cables. Makesure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in yourlaptop. A part of the screen still works fine but you cannot use itlike that so you decided to replace the screen yourself.
screen-not-working-1.jpgYou did some research and purchased a compatible screen, installedit into the laptop, turned it on and… The new screen is not working!!!What could be wrong?
Before you start to panic, check all cable connections again. Checkconnection between the video cable, LCD screen and inverter board.Reconnect cables just in case.
screen-not-working-3.jpgTake a closer look at the connection between the video cable and LCDscreen. It’s possible you accidentally pulled the video cable from theconnector during the screen installation.
screen-not-working-4.jpgThe video cable has to be seated properly, all the way down.
screen-not-working-5.jpgAlso, on some older LCD screens there are very thin pins inside theconnector. Take a look inside the connector, make sure there are nodamaged (bent) pins.
screen-not-working-6.jpgOK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one worksproperly (except the damaged area) but the new one is dead, apparentlythe new screen is defective and has to be replaced.
If that’s the case, disconnect the new screen from the inverterboard and plug in the old screen instead, as it shown on the picturebelow. If the backlight inside the old screen lights up, apparently thenew screen has defective backlight lamp and has to be replaced.
Good luck !!
ICmanServer
Jul 09, 2009 | Computers & Internet
Nokia K750i
If the new screen is white and old screen displays 20% of the display then you can check by flashing the software , in most the cases white screen is the software problem.....
Aug 17, 2008 | LG M4410 Cellular Phone
Mitsubishi WD-57732 Projection Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
