Question about Garmin nuvi 200W GPS Receiver
Garmin nivi 200 won,t turn on
I plug my charger into the back of my garmin 200 the plug in is very loose,it does not get any power. when turned on nothing happens.
    Brigadier General:
  • 4,090 Answers
Well if the plug is not making contact it cant recharge. you need to have it repaired and that may well be costly as it will require a new motherboard. Parts are no longer soldered or repaired The motherboard will be repalaced and the basic board is ^$90 the labour 1.5 hrs o 2 hrs minimum at $95 I am sure you will be able to buy a new model for the same cost
Posted on Aug 01, 2009
How do you shut the garmin nuvi 200 down I can't get it to shut off
Plug it to your power charger (connected to the el-net, of course). After the map loading has completed and you can start using it, unplug from power. A dialog box will pop up and ask you either to turn it off or to continue using it on. Choose to turn it off.
You will not be able to turn it completely off as long as it's connected to either a computer or a charger.
or you on/off push button is not working and needs to be repaired.
On my nuvi 200 the push button is a bit loose, and it easly turns on when I carry it in my pocket. Some adhecive tape will keep the button in place.
Aug 05, 2010 | Garmin nuvi 200 Car GPS Receiver
When plugging into car outlet Garmin 200 goes into computer interface mode
You have to use a car charger with sufficient power capacity for your Nuvo 200.
I've used a mini USB car charger that came with my e-trex, but it works only some times when I do plug/unplugging during map loading (manipulating the computer mode setting). So, I bought a HTC mini USB care charger, and know the problem is solved. Another alternative is buy from Garmin Store, the type they recommend.
May 30, 2010 | Garmin nuvi 200 Car GPS Receiver
My 2 yr old Garmin nuvi 200 was working fine...when I got home and turned the car off, it quit working and won't turn back on. I keep it plugged into the lighter, so it's not battery power.
No it's not the battery power: your nuvi has suffered the firmware equivalent of a stroke.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 18, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My Garmin Nuvi 200 will not charge The back of the nuvi where the charger plug goes in is loose. How do i fix it?
Please see this link: The connector needs resoldered or replaced. Common problem in the 2xx & 2xxW series.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Dec 26, 2009 | Garmin GPS
Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
My Garmin Nuvi 200 wont turn back on
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Aug 02, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
251 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
