Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Is the vista window not support the cx 2900?
I have a same problem in installed the driver but showing the USB is not connecting.
is the vista window not support the cx 2900 printer?
what is the solution for this?
kindly help me to solve out this problem,
thank you.
    Brigadier General:
  • 4,090 Answers
Check the ERpson support site to see if they have a vista driver. it is possible they dont and you may need to sell off your old prinhter and upgrade
Posted on Aug 01, 2009
    Problem Solver:
  • 28 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
apppn10
Posted on Sep 04, 2009
I wish to install a Canon LBP2900B printer under windows 7. I have downloaded the drivers from Canon but the windows system adds the printer as 'unspecified' not as a printer. It is connected by a usb...
somehow this is because Win 7 actually does not support all devices. try installing the device using win xp or vista, if it does work then it really has no support for win 7
May 21, 2010 | Canon LASER SHOT LBP-2900 Printer
LBP2900B DRIVER CD
CANON LBP2900B DriversHere is the driver for Windows 2000/XP/Server 2003/Vista/Server 2008/Windows 7
Installation Procedure when Connecting USB Cable
Do not connect the USB cable until after you have loaded the downloaded files.
After all files have been loaded connect the USB cable to the back of the printer.
DRIVERS
Thanks & Regards
M. Nanda Kishore
Dec 29, 2009 | Canon LASER SHOT LBP-2900 Printer
Canon LBP 2900 drivers 64 bit?
Now official drivers from CANON for lpb2900 win7 x64 !
http://fr.software.canon-europe.com/software/0038030.asp?model=
Jul 17, 2009 | Canon LASER SHOT LBP-2900 Printer
I can not install driver Printer Canon LBP 2900 on Vista 64bist
it could be possible that you are running on a different platform, say Vista, and you are downloading on XP vice versa, ensure you have the correct version of the driver you wish to install, unless you correctly choose the right OS, you will never make this work. sometime it is confusing really...
hope this helps
Jul 10, 2009 | Canon LASER SHOT LBP-2900 Printer
Windows 7
before installing the driver in win 7, right click the exe file of installer and go to properties. go to compatibility and click "run this in" and select windows vista in dropdown list.
May 01, 2009 | Canon LASER SHOT LBP-2900 Printer
I can't install modem drivers for SB 5100 motorola (usb) on my laptop having windows vista. An error is showing that no cable found connecting the modem and computer. Can someone help me how to set this...
Here are the current windows Vista drivers from motorola:
http://broadband.motorola.com/consumers/products/SB5100/downloads/542708-001-install-utility-b.exe
Hope this helps you on your journey
Let me know if you have anything else.
I also would recommend you use ethernet since you do not have to install any software to make it work.
You will need to reboot the cable modem when ever you change how its connected also Ethernet/USB or if it was connected to a different PC.
Please Rate
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Compability problem between LBP 2900 with Windows Vista
you will need to download the vista driver for this printer. follow the link below. enter your operating system and language information in the drop down box. under the information box that pops up you will see 1. Printer Driver (R1.11). when you move your cursor over it, it will turn red. click on that link. next you will see Software LBP2900_R111_EN.EXE. click on that line, download the driver, save to your desktop. when download is complete, close the browser and double click on the file to install the new driver.
Please take a moment to rate this solution.
Thanks,
Oct 11, 2008 | Canon LASER SHOT LBP-2900 Printer
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Problem of installation for my printer Canon LBP-2900
You can download the driver for Vista (or other OS) from the official canon website. If you cannot install the driver and see the message USB connection can not be detected, then change a shorter USB cable (1m is OK in most cases) for stronger signal. In most cases, the problem will be solved.
Mar 11, 2008 | Canon LASER SHOT LBP-2900 Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
