Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Small tube fell off Echo gas edger and it is leaking gas
I can not figure out where the tube goes so I can attach it.
Wr0ng item it was not chain saw We bought a new lowef
Posted on Aug 03, 2009
Gas is leaking after I put gas in. It looks like the fuels lines are in. Does the filter attach to the gas lines? I don't see an air filter on my 536-77240000 craftman edger.
If you just replaced the lines, alot of times the lines outerm diameter is not correct, causing leaks...other times its the gas cap itself, However, there shouldn't be any hole under a gas tank... at least not where any air filter would be close by..
Sep 26, 2015 | Garden
Schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Jan 11, 2012 | Garden
Primer bulb wont prime
Check the plastic tubes that go into the gas tank... the ethanol in the gas these days is rotting the tubing... it will break right off inside the gas tank...
heatman101
Jun 11, 2011 | Echo Garden
Whats correct gas mixture for 2400 echo edger
Your owners manual states: 50:1 Echo High performance 2-Stroke Air Cooled Engine Oil
That would be 2.56 ounces of oil to 1 US Gallon of gas.
Oct 18, 2010 | Echo Garden
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have the Echo PB 265L leaf blower. When it runs it leaks fuel down my back. Seems to be coming out of a tub that is connected to the fuel button pump (which you push to prime when starting) I checked on...
I had the exact same problem with gas soaking my back and found out the yellow fuel discharge tube that comes out of the carberator was not inserted into the rubber gasket on top the fuel tank. The gasket has 3 holes in it for 3 tubes and the yellow tube fits into one of the holes. Hope this helps. It is a bit difficult to get the tube in the hole, but at least if you know what you are looking for you can get it to work
Oct 31, 2009 | Echo Garden
32 cc Craftsman (Poulan) gas line replacement
Yes, you are right. The larger line goes to the primer bulb and only goes into the tank about an inch. The coupling just keeps the line from pulling out of the tank. The smaller line goes to the carb. This line must rest comfortably on the bottom of the tank with the filter attached to the end.
Jim
Jun 07, 2009 | Craftsman 25cc Gas Line Trimmer
Looking for the diagram for the gas tank for poulan pro trimmer PP325 SKU:952711457. All the parts fell apert inside the gas tank
You have two lines going into the tank, a small and a large one. The large one goes just inside the tank and connects to the top outlet just under the primer bulb. The smaller line has the fuel filter attached and lays on the bottom of the tank. The other end attaches to the lower outlet on the carb. Hope that explains it for you. Dwain
May 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Echo weed eater, edger and blower wont start.
TRY TAKING THE MUFFLER OFF AND CLEANING THE SMALL SCREEN OR JUST REPLACE THE SCREEN
May 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Weedeater fuel line oopsy
I fed the fuel line up through the bottom, attached the filter and pulled it backk towards the hole in the bottom of the tank. I then used a brake adjustment tool to first push the filter back in place (with the line attached) then hold by pressing down on the top of the filter while I hooked up the little plastic clamp.
All that seems to work fine but the weed eater won't idle AT ALL.
May 02, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
77 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
