Question about Nintendo Wii Console
Everything powers up and works , but the remotes won't work.
I switched the sensor bar and still no response. Both remotes power up but no hand appears and they won't work.
    Problem Solver:
  • 5 Answers
Are they synced to the wii you are using? Have you tried pointing to more areas than just where you think they'd be, you might have to adjust the sensor bar options.
Posted on Aug 01, 2009
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
Sensor
your senor bar could be bad... light a candle turn off the lights and move your wii remote around until you see the little hand... be careful not to knock over the candle... if this works replace your sensor bar
Aug 14, 2012 | Nintendo Wii Console
Incripted wii remote
1. Ensure that the Sensor Bar cord is plugged to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
2. Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
3. Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar.
Dec 01, 2011 | Nintendo Wii Console
The remote has new batteries and is able to power the Wii on and off. The A button works to move from the safety screen to the Menu. The home button takes you to the home menu. The problem is there is no...
You can either purchase a new brand-name or third party Wii Sensor Bar for 9-20 dollars at various online shopping websites, such as Amazon and eBay, or you can go into your local gaming shop (e.g. Gamestop) and purchase a wired or wireless Wii Sensor Bar.
Sep 21, 2011 | Nintendo Wii Console
Both remotes for my Wii suddenly stopped working. I think it's the ir sensor, but how can I be sure? Both remotes have fresh batteries and were working  fine yesterday. Now the wii does not register...
make sure the sensor bar is plugged in and oriented properly. If thats all ok I would be inclined to believe its the sensor bar, but you might try nintendo customer support before you go out and buy one.
Mar 04, 2010 | Nintendo Wii Console
No response to remotes
if the batteries are down change them if it still doesnt work then walk to your console at the left of where to put the disc open the cover and open the cover in where you put the remote batteries and then press sync in the wii remote and wii console just click them dont keep pushing the for more that 10 seconds or everything that is on will turn of except the wii it may not work if it doesnt ask the question for me helper9 that it still doesnt work
Feb 13, 2010 | Nintendo Wii Console
Sensor Bar
The senser bar can ONLY be used if it is ON TOP of the TV OR BELOW it.
Dec 31, 2009 | Nintendo Wii Console
Made a loud noise and then wouldn't turn on t.v.
you need to reset the configuration and it also happens when the systems been on for a long time unplug the main power supply for 30 mins and try again. hope this helps and also try and clean the disk and let them dry.
Cant get past language screen
Here are instructions from Nintendo on how to fix this issue. It's most likely related to the sensor bar. Good Luck!
If your screen appears frozen at the Language select screen, we have found that to be related to the Sensor Bar. Please try the following:
Ensure that the Sensor Bar cord is plugged snugly to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar. Please read the following:
The Sensor Bar has five infrared lights on each side of the bar that the Wii Remote uses to determine its position. If these lights aren't working, then the Wii Remote cursor will not display on the screen, and you won't be able to navigate the setup screens.
To see these lights, you will need a digital camera or cell phone camera with an LCD display . After making sure the Sensor Bar is plugged in and the power to the console turned on, direct the camera at the Sensor Bar so that it is displayed in the LCD of the camera. If the five infrared lights can be seen on both sides of the Sensor Bar, the Sensor Bar is working. While the position/angle of the camera may need to be adjusted slightly, the lights are fairly easy to see in the LCD display.
Nov 20, 2009 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
Nintendo Wii Console Logo
77 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
