Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Getting F4 error
I have a Kenmore single gas oven. In the last week I'm intermittently getting an F4 error when I try to pre-heat.
    Problem Solver:
  • 7 Answers
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Posted on Aug 11, 2009
Oven is taking to long to heat
look for the temperature sensor inside the oven cavity in the upper left or top center of the upper oven cavity,its will be a silver or copper colored rod about 1/4" by 2" to 6" long this rod senses the oven temp and cycles the heat to the oven
Jun 03, 2012 | Kenmore 30464 / 30465 / 30469 Gas Single...
My oven has been beeping for the last couple of hours. My son pushed bake and put the temp up to 425. After it preheated, it started beeping and F1 is showing on the display. I have tried everything to...
you can first try to reset the curcuit breaker
flip on and off
if this does not help
usually an f1 error is your control board
what is your full model number from inside the oven?
Apr 22, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
When oven get hot f3 come on and the oven stop
May 04, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Jan 18, 2009 | Whirlpool SB160PEE Gas Single Oven
Kenmore model # 911-494-79790
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
May 11, 2008 | Kenmore 30169 Electric Single Oven
SF114PXSBO Whirlpool Gas Oven won't heat
your ignitor is bad, the thing that glows in the broiler compartment. two 1/4" screws and one plug, simple fix. you can do it. just call a local parts store with model # and brand,
Mar 30, 2008 | Whirlpool SB160PEE Gas Single Oven
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore warm and ready draw self cleaning oven
Give me the complete model # from the sticker on the range and I can help you with this.
Nov 11, 2007 | Kenmore 33169 Gas Single Oven
Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
178 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
