Marantz 4240 receiver
The left channel on main front speakers isn't working. Is the op amp likely to have gone.
    Novelist:
  • 133 Answers
It could be the op amp, however there are other possibilities like:
- a bad speaker or a speaker cable (try some swapping, see if the left channel is still dead)
- a bad / damaged speaker connector or a bad solder contact on that same connector inside the unit
- a dirty / oxydized connector pin or a bad pin solder contact on any of the connectors inside the unit
- if the main volume pot is actually made of several pots stacked onto a common axis (unlike the standard stereo pots it will have more than six pins), see if any of the pins are poorly soldered and resolder if necessary, if it has a connector also check that for dirty contacts
These are just some of the possibilities so don't take anything for granted.
Hope you can find out what it is.
regards
3rq8 (Triarcuate)
Posted on Aug 03, 2009
I just bought a 4240 and was upset for a half an hour until fearing my left channel was gone, only to discover the little Radio Shack bookshelve speakers from the eighties that sound awesome now has a bad speaker jack! Grabbed another speaker wire and another set of speakers and the sound is truly amazing. Once again the "Keep it simple stupid" slogan applies here. What a relief!
Posted on May 28, 2010
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Can i hook up 4 8ohm speakers to my marantz 2252b
You can but you will have to put two speakers on the main L/R and two speakers on the remote L/R. DO NOT HOOK UP MORE THAN ONE SPEAKER TO A CHANNEL. Doing so can result in the amp running hot and damage will occur.
Oct 25, 2012 | Marantz Vintage 2252 B Stereo Receiver...
One channel out on the HK AVR85. Tested all inputs. Is there a fuse inside???
In an answer to to your "quest.... Is there a fuse for speaker output"
• the answer is none.
but there is a relay in between the main amp output
and the speaker terminal at the back.
In your statements : " Inputs all good ",
• Check first the line outputs at the back of the receiver , just to
determine if the preamps are working.
• connect outputs to a separate amplifier
the answer will determine
your "quest ...is this most likely a bigger issue??? ? "
I almost forgot to ask what channel are you referring to?
Say, front left channel like you said is dead,
after checking the line out there is no output either, then the
trouble or fault can be starting from the input line to these output.
These could be capacitor coupling, resistors , op-amp IC
or possibly just a cold solder joints.
Here is a sample troubleshooting :
only for Computer Speakers
(but may also apply)
• If there is an output , then trace on the main left amplifier
could be a colder joint also, check until you reach the relay.
Let us know if you have any more questions or if you need
further assistance!
Sep 19, 2012 | Harman Kardon AVR 85
I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
Assuming it is...
http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
I have a marantz sr 7001 amp and am running canton 4ohm speakers to front and centre should my amp get really hot and go into protect mode when I am giving it some serious volume
it is not made to drive 4 ohm loads.also if you measure the impedance on the speaker,at some frequencies,it is closer to 3 ohms.This will cause the amplifier to shut down.Today's amplifiers are embellished specs.the old marantz 2325 was 125 watts a channel and weighed 80 pounds.It would eat alive some of the 1000 watt home theater amps of today.Marantz is very nice stuff.
Jan 03, 2011 | Marantz SR-6300 Receiver
Will the Marantz SR5004 work with the 901?
By itself, yes, in stereo for stereo analog source material only.
There's good news and bad news for the multichannel hopes you must be harboring.
The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to receive its Active Equalization (unless they, too, are 901's of the same version) and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on most (all?) AV receivers it disables any digital inputs.
The good news. I have a 7.1 setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Just draw the Front L and R analog pre-out from the Marantz to the Bose Active Equalizer then to the new amp. Adjust your speaker levels and enjoy.
Feb 20, 2010 | Bose 901 VI Main / Stereo Speaker
Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
Aug 17, 2009 | Marantz SR-18EX Receiver
Marantz sr8002
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receivers speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Nov 01, 2008 | Bose 901 VI Main / Stereo Speaker
244 people viewed this question
 Grubhead
Grubhead
