Question about Aloha Housewares (93645) Ceiling Fan
What wire does the green wire from the ceiling connect to??
    President:
  • 1,714 Answers
To the ground lug or the metal frame, it is the ground for the fan
Posted on Aug 01, 2009
Need to know how to wire this fan. Not using a remote or wall switch
Hello! W/D here.
In your ceiling box, you'll find 3 wires; black, white and bare copper.
In your fan, you'll see 4 wires; black (or red), white blue, and green.
With your breaker tripped, connect the green wire on the fan to the bare wire in the ceiling (this is your ground).
Connect the white fan wire to the white ceiling wire (this is your common).
Connect the blue and black (or red) together, and connect these to the black wire in the ceiling (this is the hot lead, and will supply power to the fan and the light).
Best regards, --W/D--
Feb 13, 2011 | Westinghouse 78500 Casanova White Ceiling...
I have a two wire (black white) ceiling wiring and the surveyor fan has four - black white blue and green. How can I connect so that the wall unit can control speeds and light turns off and on without...
When you only have two wires in the ceiling , that means that you have only one switch for this fan. The green connects to all green and bare wires and to the mounting bracket .. the white to white .. and the ceiling black connects to the fan black and blue wires .. In this installation the fan and light can be controlled independently with the pull chains
In order to have indipendent control at the wall you would need two switches and another wire going from the switch to the fan/light
Please Vote !
May 13, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
Wiring for ceiling light
The wiring for a ceiling fan is usually pretty simple. The wires are connected color for color. that is black/lack, white/white , green to green or to the mounting bracket .. this color connection would also apply to the connections at the power source. If you have a light kit on the fan and two switches on the wall , then the red wire from the switch connects to the other wire on the fan, usually blue, if there is only one switch, or you are wiring it direct, then the black and blue wire both connect to the black power wire.
Mar 21, 2010 | Hampton Bay 24002 Ceiling Fan
Ceiling Fan
Green is always equiptment ground. It goes to the green wire ,if you have one in the electric outlet box,or mounted to the box itself itf you have not the green in the box.
Green always  to green White to white. Nutural wire. Orange to black if their is no black in the box. Orange =Black
I am also thinking that you blue will is also the positive for the fan. I woudl hook it to your orange also .  .
Jan 05, 2009 | Hampton Bay 24002 Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Nov 17, 2007 | Dryers
Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Jun 10, 2007 | Casablanca Fan 3245T Ceiling
Aloha Housewares (93645) Ceiling Fan Logo
168 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Mike Carew
john h
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
