Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
TV Flashing colors
My RCA hdtv DLP is flashing different colors. Between green red and blue... The DLP bulb was replaced 6 mo. ago... but the TV was left on for 2 and a half days on accident while on vacation. What can i do to fix this? Thank You for your time.
HEY WE HAVE A 72 INCH T.V AND IT KEEP POPPING UP DIFFERENT COLORS DURING T.V SHOWS WHY IS THAT WE JUST CHANGE THE LAMP IN THE T.V CAUSE IT HAD WENT OUT ON ME AND THAT WAS ABOUT 1YEAR AGO FROM MARCH13,2009 SO I WAS WOUNDING WHAT CAN WE DO OR ANYONE SAY EVEN IF IT IS THE LAMP CAUSE WE ARE STILL NOT SURE!!! THANK YOU E-MAIL ADDRESS IS bianca_guero_0909@doglover.com
Posted on Mar 17, 2010
Bulb goes out after a few minutes
The ballast for the bulb is the culprit. That is the circuit board directly wired to the bulb. You can get a replacement on line at:
TV Parts Universal TV Stands DLP Chips ShopJimmy It's not difficult to change it yourself .
Aug 08, 2015 | Mitsubishi WD-52525 52" Rear Projection...
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
Samsung hlr6167wx A noise like fan winding down started occuring , like spinning whurring sound then the picture went out. I replaced the bulb 3 years ago. Can this be a bad fan and a bad bulb too. All...
if this "whirring" sound was making a vibration on the TV, there is a good chance that the one that needs to be replaced is the color wheel. When the color wheel fails it also triggers the signal for replacing the lamp. This is another common issue with Samsung DLP's.
In order to replace the wheel follow this picture guide:
http://www.fixyourdlp.com/guides/samsun ... 01579a.php
You can purchase the wheel for your TV here:
http://www.discount-merchant.com/Samsun ... 1&CartID=0
Jun 26, 2011 | Samsung HL-R6167W 61" HDTV
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
1,224 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
