Question about Panasonic AG-DVX100 Mini DV Digital Camcorder
I am in the middle of a shoot and my Panasonic AG DVX100A will not record. I was going through menus for setup, and the screen is stuck on "USER SW" and shows the 3 user switch settings. Menu button doesn't work, and neither does record. I have tried resetting it numerous times.
  • jason322 Aug 01, 2009
    I have removed the battery and re-powered the camera numerous times, still stuck on the menu. Also tried pressing the reset button with the battery installed and not installed. Still no change.
    Messed with it a little more, got the menu button to work, seems the joystick is not working, and may be my problem.
  • 11,896 Answers
This may be a fimware proem or a bad capacitor and i suggest taking to Best Buy or other shop.
Posted on Aug 02, 2009
    President:
  • 1,714 Answers
Remove battery for a reset, then try again.
Posted on Aug 01, 2009
  • Craig Butler
    Craig Butler Aug 01, 2009
    User switch? Have you checked all your switch settings? Can they be changed to anything else. Try pressing all at once...
  • Craig Butler
    If all else fails it's time for 'percussion maintenance' That means a good wrap on the hand a couple times. I'm serious, what have you got to loose?
Where can I purchase a head cleaning tape for a DVX100A camera?
Screen? Had the same problem. It's an internal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Sep 28, 2009 | Panasonic AG-DVX100A Mini DV Digital...
My Panasonic DVX100A is not recognizing the tape what could be the problem?
most likely problem is dirty video heads. try a Panasonic cleaning tape; if that doesn't work, hand cleaning by a technician should work.
Jul 27, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Dvx100a showing black screens on lcd screen and view finder
You probably have the lens cap on, the iris dial closed, or you are in vcr mode rather than camera mode. You may also have the nd filter set to 1/64th, this is only for bright sunlight. When shooting indoors with low light, set the nd filter to off and hit the iris button until iris manual appears on the lcd, then dial the iris dial in front of the iris button up or down to bring the iris to around 5.6 f stop.
Feb 26, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Panasonic dvx parts
We are one of the Panasonic ASC and so far we had no problem with DVX100P parts. Although that model has been discontinued parts are still available.
Most of the DVX100A parts are common for DVX100P
Eric
www.Digitronelectronics.com
Dec 17, 2008 | Panasonic DVX-100 Camcorder
See audio levels but don't hear
ADJUST THE AUDIO OUT LEVEL WITH THE AUDIO MON/VAR ON TOP OF CAMERA
Oct 10, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Tapes won't Playback in other deivice
Hello! If the recorded tapes playback ok on the camera and not ok on another devices, you need to readjust the playback on this camera using a tape which playbacks fine on the other devices. This means that is a small difference on the tape transport. So when the supply and takeup post rollers readjusted and the audio and video playback are good, then your camera is fine.
Sep 14, 2008 | Panasonic AG-DVX100A Mini DV Digital...
DVX100A panasonic camera tape mechanism not working
You can open the cassette cover and spray inside the upper left side of mechanism(closer to the back) with contact cleaner spray,because there is a rec inhibit switch.If it's not damaged and just dirty you solve your problem ,but if is damaged it needs replacement.
Jul 26, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Problem with recording
this problem is caused by defective power and record start/stop switches. they are still available from Panasonic.
Jan 21, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Panasonic DVX100a Unexpected Shutdown
It sounds like an automatic battery saver function. Regarding the need to return to the menu to select your settings, you can program these into the user file settings, so all you have to do if it powers down again is select your user file. The manual can be found at: http://service.us.panasonic.com/operman/findmanual.aspx?model=AGDVX100 BTW, aside from the need to save your battery, it is harmful to both your videotape and video head to keep the tape and head engaged onger than two minutes.
Jan 10, 2007 | Panasonic AG-DVX100 Mini DV Digital...
Panasonic AG-DVX100 Mini DV Digital Camcorder Logo
52 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
