Question about Sewing Machines
I have a Janome MemoryCraft 300E embroidery machine and I am having problems with the thread becoming all bunched up/ knotting up in the bobbin case and between the under side of the fabric and the bobbin case. Please help
  • Sewing Machines Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
I have a Janome MemoryCraft 300E embroidery - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Aug 02, 2009
My Janome 8050 bobbin case is jumping out of place. The thread is wrapping around the bobbin case and getting stuck, bunching up, and shutting down my sewing progress. It ties the needle up.
check for the retainer action of the bobbin case to see in there is a part broken off that holds the bobbin in the case or carrier
from what you describe , with the thread bunching up etc, I suspect that the needle thread tension is too loose and causing the problems
if so then the bunching and problems can be from the bunched thread pushing the bobbin out of position
take it in for a service and if necessary , repair
Dec 20, 2016 | Janome Sewing Machines
HOW DO I FIX A FM PHASE ERROR ON MY JANOME 6500 MEMORY CRAFT
Check your Feed dog switch for raised or lowered positioning and reengage to either setting and rotate the hand wheel to reengage the gears properly.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 28, 2014 | Janome Memorycraft 6500P Computerized...
Bird nest when trying to sew. Under material by bobbin - tried changing needle, bobbin. Tension - no change to the problem from Auto for regular sewing to 2 for embroidery
i think you have something catch on the tension guides. Try to clean out anything you can see and pull a thread towards the needle. I have done this with a small knot to snare anything but be gentle. Also, rethread carefully.
Try cleaning the bobbin case too
Sep 12, 2010 | Janome Memory Craft 9500 Computerized...
The top thread on my Janome 300E is getting caught in the bobbin. It starts bunching up on the back of the fabric that I am trying to embroider and it gets stuck. When I pull it off all the top thread is...
If your thread is getting caught underneath it's usually the UPPER thread is threaded wrong or not correctly through the tension discs. This can also happen if you're using Sticky Back stabilizer. Make sure you have a new needle in case there's a burr on the old one which can also cause this problem.
Aug 22, 2010 | Janome Memory Craft 3000
My Janome mc9700 is giving me trouble. I think it may be a tension problem, but I'm not sure: trying to get some advice before taking it to the dealer. I am in the middle of an embroidery project, and my...
1.check to see if needle is in backwards
2.the upper tension maybe to tight----check owner's manual for right tension
3.the needle may be bent--roll on flat surface to check
4.the thread maybe hanging up on the bobbin case
5.check this area for lint or fragments of old thread
6.check thread for knots, if notty replace
Jul 29, 2010 | Janome Memorycraft 9700 Computerized...
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Feb 14, 2010 | Janome Memory Craft 10000
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Sewing Machines Logo
285 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
