Question about LG RZ-42PY10 42 in. HDTV Plasma
I have a LG RZ-42PY10 42Plasmareen which changes to red after 10-
I have a LG RZ-42PY10 42" Plasmareen which changes to red after 10-15 mins and then turns off.What could it b?
  • arnaud73 Aug 26, 2009
  • arnaud73 Sep 07, 2009
    Hello there,
    I removed the back cover and powered the unit up. Neither if the fans is functioning. I can trace these back to a small (regulator) board to the lower left of the chassis.
    Does this offer us any clues?
    arni
  • 1,869 Answers
This is a cooling problem; the i.c. "chroma" chip is cooled by the use of a silicone cream (this can be purchased at Radio Shack stores or; online; and, fans (if the temperature gets too high the tv will;by design: shut off for safety, so; first: check to see that the fans on the back of your tv are not blocked with lint or, not running at all (listen / feel) then: if you feel confident; open the case and, observe the fans; check the temperature of the chips and, the condition of the cream (must not be dried out) unplug first! you can also use component cooler freon to spray the chroma chip to cool it while it runs; be carefull! while the tv is plugged in! Hope this helps!
Posted on Aug 26, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The red tint on the screen is due to a bad lamp or a faulty inverter board. It could also be a dry joint somewhere in the drive electronics. Lamp faults are often intermittent as they can be dependent on temperature among other things. This can make internal shorts come and go. Service Engineers will often take the back off the set and gently tap the neck of the tube to prove or disprove the lamp problem.
Please get this checked as disassembling the tv could be very dangerous as it has very high charge even when its switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Aug 26, 2009
    Hi
    There is an internal short on the circuit board of your tv & due to this the tv screen first turns red and then after overheating(due to short circuuit on the board) it turns itself off. However, these kind of short circuits on display board cause the lamp to go bad.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Sep 07, 2009
    Hi Arni
    If you can't see the fans moving and neither anything appearing on the screen then due to shorted connections and which resulted in overheating of lamp. Further checking the TV circuit is not advisable as i have earlier told you that the TV contains very high voltages even when its switched off and fiddling with any unknown part/circuit can be fatal.
    Thanks
    Rylee
Tip
I AM LOOKING FOR LG PDP TUNER CONNECTION CABLE (25-15/9 pin).
PLS PLS I AM LOOKING FOR CONTROL CABLE FOR 25-15/9PIN FOR PDP TUNER RZ-BA 10 SO PLS ANY ONE THAT HAVE THIS SOLD PLS LET ME KNOW THE PRICE TO PAY FOR IT.
Make: LG
Model: MZ60PZ10
Appliance: TELEVISION
PDP Tuner : RZ-BA 10
Description: LG PDP CONNECTION CABLE MZ60PZ10
(25-15/9 pin
on Aug 20, 2010 | Televison & Video
LG RZ 20LA90standby light flashes from red to green
Hi, this description usually indicates power supply failure, you can verify this by checking the output voltage of power supply. Cause of the error can be electrolyte capacitors. You can identify them by swelling at the top of the condenser. If you have the technical ability? so there are a few more options for testing. In any case always possible to replace all power supply. Good luck! Let me know if everything worked out, or if you need further guidanc
Feb 28, 2011 | LG RZ-20LA70 20 in. LCD Television
I have a Gigabyte 7vt600p-rz motherboard. How do i disable the Bios Security password on it so i can change the boot sequence ?
Clear cmos, you should have a clear cmos jumper on your motherboard, just move the jumper from the normal position to the clear cmos and then back. Or you can remove the lithium battery for atleast 15 min.
Nov 17, 2010 | Gigabyte 7VT600P-RZ (GA7VT600PRZ)...
Keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Aug 07, 2009 | Televison & Video
Sky remote code
0206 usually works for LG
Let me know if any success
Feb 07, 2009 | LG RZ-15LA66 15 in. LCD Television
LG 42lc7d 42" lcd
Replace power supply and this should take care of all of you problems part number is EAY34797001.
Josh
Feb 09, 2008 | LG RZ-20LA70 20 in. LCD Television
LG RZ-20LA70 How do you....
I'm trying to plug in a RZ-20LA70 TV into a Sony DVP NS29 DVD player? Which wires (red, blue, green) go into the coaxial, audio L, audio R, video slots? Thanks, Simon
Jan 14, 2008 | LG RZ-20LA70 20 in. LCD Television
LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
Jan 10, 2008 | LG RZ-37LZ55 37 in. HD-Ready LCD...
LG RZ-42PY10 42 in. HDTV Plasma Logo
53 people viewed this question
Computer Repairing
Computer Repairing
