Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Free agent go external usb; displays: o bytes capacity and 0 bytes available. both blue, no pink is displayed. says need to format. I know have data on this drive from before. shall i format it? I might loose all the data. have windows 2000 also tried on XP. in the prperties I see the circle in complete blue. thanx, nasser
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
My one week old usb today said used capacity 0 bytesfree 0 bytesfile system raw.cannot be formated.it says insert flash drive. This happened the last new usb device I bought three weeks ago. Is this a...
This is probably a problem of system files on the USB key.
First of all, read the manual for the key, and verify that no utility provided with the key to reset or reformat. If such a utility is present, it is recommended that you used same before proceed to next step.
Otherwise, to reformat and therefore repair the USB key, you can use standard tools of Windows. Insert the key into the USB port of a PC, then go to:
Start / Control Panel / Administrative Tools / Computer Management / Storage / Disk Management /
Select the drive to the USB key in but ensure same is not a hard disk system!
Once the back up of your USB key effected, delete the existing partitions on the key (right click / delete the partition.). Format the key to FAT16 using all the available space (right-click / Format). For more than 2GB, it is recommended that you format same as FAT32.
If the available space is under the capacity of the key, this is surely a hardware problem, in which case it may be necessary to reduce the after-sales service.
It should be noted however that a difference of about 10% should not be considered, prior the way the manufacturer has recorded bytes. To be more appropriate, as a manufacturer considers that a Megabyte equals 1 million bytes or 1024 * 1024 bytes, a key of 512 MB can display 512 000 000 bytes or 488 481 250 bytes.
May 14, 2010 | PNY USB SmartMedia Reader PC (SFRUSBWB)
On opening a pen drive it is showing 'please insert a disk into removable disk (h:)' and opening its properties it is showing used space 0 bytes free space 0 bytes
Hello there yogeshpat876.
Here's your geek-steer ...
Is this a new drive? If so, it probably just needs to be formatted [and optionally assigned to whatever free drive (letter) you desire]:
Start > Run... > tpye "diskmgmt.msc" (without quotes), then OK
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Transcend (589307) Media
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
1GB MicroSD card detecetd by computer as 0 memory device
Clean the contacts with a pencil eraser
Use a Photo Recovery tool.software
use HP USB Format tool from Extreme Tech
http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting.
If none work, it is hosed and only I can fix it so let me know ;-)
Jan 14, 2009 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
Pen drive is not able to write any data
How are you formatting it? NTFS or FA32?
I suggest you reformat as FAT32
Dec 19, 2008 | Electronics - Others
How to format raw sandisk 250 hard drive with window xp.i couldnot use this mp3 player after i used this device to transfer files from one computer to the other.after transferring the file,i deleted the...
Alright, plug the player in with your USB cable.
Open "My Computer" and find in on the list of drives and CD-Roms. It will be called something like "Audio Device" or "Removable Storage Device". Make sure you find the correctly icon for the player.
Right click the player then select the format option. You'll probably want to use a FAT32 format as it is the usual format for MP3 players and flash drives of the like. This will totally erase any files on the player, so be forewarned before you complete this.
Raw file system is basically the media in it's standard state. All the information is recorded as zero's and this is how your computer is seeing it. It is either reporting incorrectly due to bad file system error, or simple was formatted incorrectly.
Give that a try, let me know what happens. :) Hope it helps.
Sep 21, 2008 | Audio Players & Recorders
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
171 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
