Lucking for universal remote control o original remote control for hdtv for 19la20q proscan tv please help
  • 19,396 Answers
The original remote is not available.
The best choice is getting a custom rebuilt copy of the original remote .
You can order a custom made remote here. contact them using the form.
Universal remotes should also work on this TV. Just check that they have Proscan codes before buying.
This one for example
has PROSCAN 000 031 107 181
Posted on Aug 01, 2009
What is the universal remote code for Proscan Model 19LA20Q
You have this backwards. You really want to know how to get your unidenfified remote to control your Proscan TV. The code is generated by the remote.
Feb 14, 2013 | Proscan Televison & Video
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
Do you sell remotes for 19la20q and if so how much
Try remotes.com to buy to buy an exact remote to the original.
Jun 15, 2010 | Proscan 19LA20Q LCD TV
My Proscan 19LA20Q Keeps going to sleep mode after my sister touched something on the remote. The Blue screen and the source flashes on for a few seconds then the light goes orange and the screen goes...
ur sister possible turned the sleep mode on.......check on ur remote that is is off......if this problem persist u have to call service to fix ur problem
Nov 20, 2009 | Proscan 19LA20Q LCD TV
My daughter has drop the remote control in the garbage. I have purchased 2 universal remote controls. neither one was able to work with this Tv : Proscan 19LA20Q. Where would I be able to find a Proscan...
You will be required to order the original remote for your set. Universal remotes will not work properly with this model.
Start at the link below. You will need the model number. The Panasonic support person will tell you how to order a new remote unit for your set.
http://www2.panasonic.com/consumer-electronics/support/
Jerry G.
Oct 10, 2009 | Proscan 19LA25Q 19 in. LCD Television
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Replacing remote for Proscan 15" LCD HDTV
Most universal remotes work on a small portion of TVs in the market place. And if it does work, they are limited. Because the universal remote cannot control the full functions of the TV.
Like menus, screen modes,close captions, and etc.
Best thing to have is the original remote.
If you need to find one, let me know. I know a few good web sites. I just need the model number of your TV.
I hope I answered your questions. Please rate me. :)
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
Feb 17, 2009 | Proscan 32LA30Q Television
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
