Question about Canon Pixma MP500 All-In-One InkJet Printer
The printer displays a UO71 message saying that there is more than one tank of the same colour ink installed when in actual fact all the correct cartridges are in place...
    President:
  • 2,306 Answers
You have a defective ink cartridge, usually the one whose light doesn't light when the carriage comes to the center position.
Posted on Aug 01, 2009
UO43 error there is no ink cartridge there, but when there is an ink catridge UO71 it says more than one ink cartridge
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 08, 2010 | Canon Pixma MP500 All-In-One InkJet...
Getting a UO71 code saying more than one ink tank is installed. The ink tank is full
Thats a defective cartridge, you need to replace the one whose light is out when they come to the center. Canon will replace defective cartridges for 30 days after purchase.
Nov 10, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Alarm: UO71 more that none ink tank...
That means that you either have a defective ink tank, or there are two of the same color installed, check the label for the inks, the one that flashes is the one with a problem.
Oct 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Alarm light is on and it won't print
I get the same error message. I pull out the yellow cartridge and put it back in. It will print a couple of times and I get the same message. Need a permanent fix.
Sep 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
i had the same problem and when i checked inside to see why it was not working with the cyan i saw that a sensor was the problem... it had fallen out. check it out and let me know if it is the same with yours.
May 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500
When installing or replacing an ink tank, only one of the ink tanks should be installed. If the ink tank is not installed correctly, an error message will display.Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
Give a thorough check up to confirm any colour ink is not twice loaded (cannot be loaded in a single slot,may be in another slot )
May be any defective ink cartridges
Mar 13, 2008 | Canon Pixma MP500 All-In-One InkJet...
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
Aug 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
IP4200 duplicate ink tanks.
Hello there scubadave,
I've gotten in touch with Canon and have somethinga little different to try. At the very least the error should change.(Sorry, gallows humor). Please read this entire response before takingaction.
After the upcoming test procedure, I have included alink and procedure to contact Canon tech support. The assure me theywill replace any faulty tanks.
The purpose of this exercise iseither rule out ink tanks that are behaving or isolate the one(s)responsible for the dupliucate error. You should write down the results of thistest. Please perform the following:
3.Confirm whether the printer recognizes the installed tank properly. Ifit does, it will indicate it does not detect the other ink tanks, asthey are not currently installed in the printer.
5.If the printer at any time indicates two of the same ink tanks areinstalled, the cause will be the last tank installed. For example, ifyou inserted an ink tank earlier, and you later inserted another inktank, and it said two of the same inks were installed, the cause of theissue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error- Duplicate Ink tank problem on my Canon PIXMA iP4200
<Describe how error occurs>
I have replaced the <color in> question> tank, reseated it, yet the error continues.
Youwill also need to list what inks are being used in the printer. Statethe type of ink that is being used and the order that the tanks areinstalled in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the test results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Remember: Good things happen to those who Rate.
Mike
Aug 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
My printer won't print because there is more than one inktank of the same colour
There are 2 types of black cartridge, CLI-8Bk Black Ink Tank & PGI-5 Pigment Black Ink Tank. These must be installed in the correct order as below. Have you replaced a black cartridge & perhaps used a different type? Here is a link you can get more info from: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11994
Aug 05, 2007 | Canon PIXMA iP5200R InkJet Photo Printer
Pixma mp500
Canon Technical Support team will be able to help here. This seem a common problem with the printer firmware.
Jul 08, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
old marine
old marine
